Interesting you say that. I am now reading on forums etc that Rosberg turned up his engine in Bahrain and in Spain Hamiltion turned it up to keep him behind. Everything I have read from Lower and Toto suggests that it was only Hamilton that played with engine spec against teams instructions. In Bahrain Rosberg was able to do so as it was his strategy to do it at that part of the race...so wasnt disobeying the pit wall in doing so. Seems Lewis saying Noco did the same thing in Bahrain is what people are remembering....and that is a statement out of context
Does anyone have a link that confirms Nico disobeyed the pit wall in Bahrain?
http://en.espnf1.com/f1/motorsport/story/160127.html
However, Wolff revealed that the tension dates back to the epic battle between the two in Bahrain where Rosberg was using engine modes that Hamilton was not and then Hamilton did the same when the pair were racing in Spain in two weeks ago. Wolff played down the significance of the two incidents, but said it had added to the tension in Monaco and would not be allowed in the future.
"In the last couple of races we had some little fouls left and right, and in the team we made sure this is not happening again," Wolff said. "The most obvious bit is you can play around with the engine modes, so this is not happening ever again.
Cheers, that suggests that Rosberg may have disobeyed the pit wall. Other quotes suggested that Rosberg was allowed to be in that engine mode and Hamo didnt understand why Rosberg was allowed to use a different setting...seemingly associated with Rosberg running the more conservative tune when on the harder tyre.
I recall thinking that was odd as if my memory serves me right comign down to the last laps in Bahrain Rosberg had used more fuel so didnt really support he had been in a more conservative engine setting mid race
yeah ive heard different things too, i think in the f1 telecast they talked about the engine mode being one that they are never to use.... but who knows....
in other news
http://en.espnf1.com/f1/motorsport/story/161097.html
'murica....
Yeah certainly sounded a little but suss. Every other time they'd choose to come out last so that they can shut the car down early if they aren't going to be beaten so as to save the tyres, etc.
It's going to be an interesting run into turn one. I think that if homo can get in front into turn one he will lead from start to finish. I don't think britney has the overall pace that homo does, he just managed to turn it on for 1 lap
yeah definately he was so close with a couple of mistakes, so yeah rosberg's gonna have to pull something out of his arse....
hamo has said going out last was prob not a good idea getting caught up in traffic....
maldanado reprimand for not putting his steering wheel on...
hopefully williams can have a good race!
Disappointing for Williams. I think Perez was at fault but Massa showed today that he is past his best and really should have got the job done as soon as he arrived on the bumper of Vettel. Cant help but wonder the 2012 Williams would have had if they kept Rubens and this year if they had someone like Romain
Funny to see Button in 4th...the guy is quick for one stint in 6
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
