poor Kimi, 7 tenths slower than his team mate.
that's as much the problem as the strategist's call to not go out again. If he had done a decent lap - no, scratch that - if he had even managed to do a lap within half a second of his team mate, he'd have been 6th in Q3 instead of 17th and eliminated.
but it was also a crap call by the strategist not to realise he was too slow.
