http://m.speedcafe.com/2014/11/18/ten-foxtel-set-share-f1-rights-2016/
Could be interesting, I hope they don't go the way of v8 supercars and put most of it on foxtel.
Thank f**k for that. I hope channel 10 lose it completely
qualifying exclusive to Foxtel, races broadcast on both according to an article I saw yesterday. Doesn't really matter - just stream qualifying.
I'll be getting Foxtel just for this... Was already going to get it for next years motoGP season, but this just makes it an even easier decision. I'm guessing the foxtel coverage will pretty much be a direct feed of the UK broadcast, either Sky or BBC, and won't have ad breaks during the race...can't wait :)
  • Like 1
McLaren is planning on completing its first official test with its Honda power unit during the two days of testing following the Abu Dhabi Grand Prix.
Read more at http://en.espnf1.com/f1/motorsport/story/184393.html#Lg4CHeMPkH8KF1SY.99
Formula 1 boss Bernie Ecclestone has handed financially-troubled team Caterham a boost as they return to the grid at the Abu Dhabi Grand Prix.
http://m.bbc.com/sport/formula1/30116227
Yep apart from the MotoGP and AFL, Foxtel really has nothing to offer. If they had any sort of competition they'd be out of business by now.
Well they really need new subscribers because Netflix is going to kick them in the arse quite badly here i'd wager.
Yeah that's what I was getting at...They offer nothing....Their ads run longer than FTA TV, and contain plenty of product advertisement, not just ads for other shows on Foxtel etc.
I remember when I was young and my parents first got it, the ads would run for literally 15 seconds, if that, and were solely to tell you what was coming up next or what was on another channel etc. In my opinion, you pay for the service so that ads aren't needed to pay the bills.. Foxtel has thrown that out the window, all while increasing prices at the same time..
I will get it for the MotoGP/F1/AFL next year, but I'll hate myself inside for contributing to the cocksuckers at Foxtel.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
