Cool idea. Nice to see something like this over there. 89 R32 GTR can be imported to the states this year...... :woot:
thanks man!, and hey , how are those ID1000 treating you? im thinking about getting those as well as a twin feed fuel rail.
Okay Ive got a couple of questions for you guys that know your stuff.
1. I have no idea where this goes to, i think its for one of the lines that goes to the carbon canister but ive got rid of all of the hardlines on the rb as well as the two that was for the carbon canister. Can this just be capped off? or left open? and what are the effects..its only on this one itb and it doesnt look as if it goes to the valves...
2.Has anyone seen this setup before? looks like it goes to the balance tube. but...theres three plugs? and if it does or doesnt go to the balance tube. what do people who get an fittings for their valve cover do with the port on the balance tube that has a restrictor that came from one of the ports of the valve cover..looks like it was for blowby maybe? idk.
c6b72d72-0e8e-4ecd-833f-7c5b2c2fb924_zps
  • 1 month later...
Well, if anyones wondering why i haven't posted in a while , its cause i took my engine apart...you know just to double check on some things and was not happy with what i found ..whoever had it before, wasnt taking good care of it. Feast your eyes lol
photo3-3_zpsebef457a.jpgphoto2-3_zpsa4ba8764.jpgphoto1-3_zpsd0400fc9.jpgphoto4_zpse4048fbe.jpgphoto2_zpsde44d33b.jpgphoto4-1_zpsd5289c10.jpgphoto3-1_zps20241fa3.jpgphoto2-1_zps7d2855eb.jpgphoto5-2_zpsc3dfaac4.jpgphoto4-2_zpsf7ca5e60.jpgphoto3-2_zps159d2b15.jpgphoto2-2_zps6fb18eb1.jpgphoto1-2_zps53d4d0e3.jpgphoto5-3_zps83591d65.jpgphoto4-3_zps8239065d.jpg
SO, after seeing all that, where i'm at right now is getting the head and block machined and cleaned etc, bore to 86.5 most likely after seeing those cly walls just to be safe..anyone have any specific things i should have done to the block/head as far as machining and cleaning etc that has to be done at a machine shop? much appreciated
Sorry for the late reply. The ID1000 are fantastic. Idle perfect and have never missed a beat. Highly recommend.
If you don't mind me asking, what kind of rail are you running ?
Well that's f**ked.
I'd be getting a thorough inspection on that head by looking at those valves. Also make sure you get all the oil galleries enlarged.
Wouldn't getting the oil galleries enlarged lower my oil pressure? Why would I want to enlarge them?
I run ID1000's too on the stock rail. Been in there for the last year without an issue.
tempting.. i do still have my stock rail, but i dont know. i think im just going to go aftermarket. Ive already dropped my fuel tank and tossed all the stock hardlines for fuel so i need a fuel rail that implements an lines. running an lines all the way back to fuel cell.
If you want 600HP you will need a bigger fuel rail. They are not expensive and worth the upgrade. And they look better :yes:
Yeah, ive been looking at this RawBrokerage Twin feed fuel Rail with ID1000 injectors. will more then likely go that route. and dam right, they look better lmao
  • Like 1
Yeah just do that. Job done :thumbsup:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
