Okay, I need to clarify something.
I am not in this business. I was sick and tired about all the BS about OEM swaps and decided to research this topic and found people in Europe who are capable of delivering what I need. They have a track record doing the same things with USDM and JDM models for much wider range of cars, not only V36, I'm still interested in this topic just because the same swap can be done on Series 3 E51 Elgrand which I have atm.
Given the guys will come from overseas to do the work, you either need to trust them or not; any warranty will be useless here once they fly back. However, I'd imagine nobody would make hundreds of cars somewhere else and then travel for 21+ hours just to rip off poor V36 owners in Oz for $500 a car given the cost of replacement equipment circa $2k
Edited by Zveruga
Yep fedor karmanov and his people. Fully aware of him.
Point I'm making is when you present an idea someone else sees a cheap way of doing it with disastrous results.
Worse when they start hacking on harnesses and render the car useless. I'm told this is the case with this one.
Problem being is this. We both know the car is unique to japan and nothing else direct swaps into it without modifying hardware or software.
Doing hardware as we know is expensive. Doing software on it requires a custom solution that few want to pay for (and the reason I quit doing it) .
E51/E52 el grand are similar platforms to these cars but few are going to play with those. Those vans are in English in Singapore and for what it's worth I have the service manuals for both.
Now in saying that I can almost bet someone tries to swap the main controller in one and destroys something.
IIRC these problems have been happening since v36 landed here.
Many smart chaps bought random US gear from eBay and tried to replace the units and failed.
Adding more story to the list does not change anything and this story has nothing to do with what we're discussing here.
Hundreds if not thousands cars have been converted in Russia in the past few years, now we will have the same tech but with Australian-specific firmware.
Now you see why I stopped.
Its not about ripping people off.
Its about if something goes wrong the day after they jump back on a plane, the owner is left with an issue they need to sort out themselves with no recourse.
to be honest, i hope it works out, because the demand for these conversions will become more and more as more modern cars hit Aus from Japan,
good luck with it all.
Absolutely agree.
People (Fedor and Ko, and his competitors, too) who found the way to make it spent quite some time with test cars and stands to make sure it all works. Any random guy buying stuff from eBay would just screw up his car with 99% probability. Just to say it again - it is not easy, but it is doable.
The only thing I would disagree is the uniqueness of electronics - on the software/locale side, yes, it might be the case but this is not where changes are done. The approach we are discussing here works pretty much across JDM, USDM and even EU cars successfully. Many importers of US cars to Europe (the market whose size makes our tiny JDM import market cry) have these boxes fitted for years already.
Yes, unfortunately many cars have to have their components replaced, however this had been done many times on a such widespread model as the V36, so it hardly requires any proof that it will work. The same solution successfully works for cars as complex as the R35, converting from USDM and JDM to other regions.
The turn-key solution is expected to cost US $2.5k or some nearest number depending on car type, model, etc. It is not cheap, but brings all the goodies like FM frequencies, DVD playback, native Oz touchscreen navi, steering wheel controls, like in ADM models. One need to decide whether it's worth $2.5k or not. It is hardly can be done cheaper than that, though due to the cost of components involved.
As of the E51 conversion, it has been already implemented, check this out:
Pay attention to how's lovely the English controller buttons look like, too.
The E52 conversion was known for years, as they as easily doable as the V36 Series 2, I believe you understand what I'm about. Like this
Edited by Zveruga
Fair enough. Actually being in the first batch in Australia is not for faint-hearted and I was trying to make it very clear. Will definitely post a report on how it will all pan out.
I see points in both cases here, but if you (Chris) is doing all the research because HE wants to sort it out for his own vehicle etc, then it would be kind of monopolizing to not help out his fellow nissan enthusiasts OR guide them in the right direction. If he is doing it to make a business out of it (doing the research for other people etc) then he is well within his rights to charge whatever he wants.
/endthread
To be honest I quit doing this a fair while ago. So as far as having a monopoly on it. No. There are plenty of people in oz capable of doing this but they will all refrain from sharing due to the amount of whinging that's associated with it.
  • 8 months later...
Serious question as i'm looking at V36's,
Given you'll be charging for this and your confidence in the product, i take it all work will come with the relevant warranties?
Hi u can visit my website or give me call
http://japtoenglish.com.au
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
