We are pleased to announce that Skylines Australia Victoria is now an approved Car club to be registered in the Vic Roads Club Permit Scheme.
In order to implement the Club Permit for our members a few ground rules needed to be set to ensure that there is no abuse of the privilege, as any misuse will result in the entire club & its members being stripped of eligibility.
Conditions are as follows:
1. Be a SAU VIC Financial member for at least a year
2. Attence of 4 club events per year. A club event is defined as:
a. Deca
b. MS Championship
c. Show N Shine
d. Any members only events
3. No RWC required. However a club official (exec) will inspect the vehicle for:
a. occupant safety
b. pedestrian safety
c. noise
d. mechanically sound
e. suitability for vehicle to driven on the road
d. approvals will be at the discretion of the official (exec)
From VIC Roads:
Conditions of use
VicRoads may suspend or cancel a permit if the permit holder fails to comply with the permit conditions or engages in conduct which threatens public safety or undermines the integrity of the permit scheme.
  • Club Permit vehicles can be used at any time for any purpose other than for the carriage of goods or passengers for hire or reward. Permit holders are not restricted to club sanctioned activities when using their vehicles.
  • The vehicle that is being driven on a valid Club Permit must be maintained in a manner which ensures that the vehicle is in a 'safe condition' for use on a highway.
  • A logbook must be carried in the vehicle, or on the rider (in the case of motorcycles), at all times the vehicle is in use. On each day of use, a logbook entry must be made prior to the vehicle being used (unless the vehicle is within 100 metres of the garaged address).
  • Ensure that the Club Permit number plate(s) and windscreen label as issued by VicRoads are correctly displayed on the vehicle at all times.
Applying for a club permit
To apply for a Club permit you will need to complete a Club Permit Application form together with:
For More information: http://www.vicroads.vic.gov.au/Home/Registration/PermitsModificationsAndDefects/OtherPermits/ClubPermits.htm
There may be some minor details so I will update this post or thread as we progress with the implementation
https://www.sau.com.au/forums/topic/436427-sau-vic-club-permit/
Good work Tony on making it happen. I'm sure there will be number of people jumping on the opportunity to make their car club rego'd.
I've one question, about inspection by club executives, what sort of 'qualification' do they require to have before doing inspection of cars? (That question is just to satisfy my curiosity, feel free to PM if you don't want to share the answer publicly).
No qualification guidelines have been set by Vicroads that I have been advised of. Its more of a self-assessment system. Make a reasonable assessment by those that are authorised by the club.
I've been waiting for this. I was going to sign up with another club so I could get club reg but now now I don't have to go anywhere.
I take it the 25 year rule still applies?
Also, where will the vehicle assessments be done?
Is there a contact number for the person that will be going over the vehicles so we can find out what will pass and what won't?
will this get us access to historic plates????
historic plates???
these are jsut the standard club plates:
  • Number Plates
    Club Permit plates have white characters on a maroon background.
    When submitting your Club Permit application at any VicRoads Customer Service Centre, in most cases you will receive your number plates on the spot. If you submit your application by mailing it into VicRoads, you will have to wait for the delivery of your number plates.
    Custom plates cannot be issued to a vehicle on the Club Permit Scheme.
and from a few messages received.
No this is not a way to get your stripped out heavily modified track only car
or your defected Drift car back on the road.
oh and no compliance plate..we cannot help you.
these cars do have to be Safe and basically close to roadworthy
remember we are going to be sharing the road with them.
And remember you will be even more representing the club whilst using this system.
and EPA is separate to to rego so there no getting around that...
it's more for the person with a nice clean car who does not drive it much and looking for some cheaper rego on it.
In addition for modified vehicles, it isn't that easy you till need a VASS certificate:
Cheers mate. It's a fairly standard car other than the half cage, which I'm fairly sure is still legal so long as the car is registered as a 2 seater.
I'm also pretty sure fixed back buckets are legal so long as they are FIA approved.
Are you able to provide some info on who will be doing the checks and where?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
