HKS actually use the OEM VQ25det manifolds in their old kit except for the crossover part of the manifold behind the engine so we know they will bolt on.
Everything else is pretty similar so I can't imagine why it wouldn't... except for the loom/ECu side of course
Edited by iamhe77
Yup, but HKS also have that weird flange adapter for the the turbo.
But also changing ECU means you have to go RWD manual though? Otherwise wouldn't you have the change the whole driveline?
Manifolds isn't the main issues. Yes, they bolt on, but the engine management side of things would be the biggest head ache.
Also sorting a turbo and wastegate to suit the 3500cc with the confined packaging.
Change ECU and loom to the PNM35 items. I do not know if it has different connectors than the VQ25det for the speedo etc
Then just run a piggyback or get it flashed.
Change all the ecu's and all the looms. Don't like the sounds of that, too much work and headaches, and for what? The VQ25det is the better engine, unless you plan to drop 15k into the VQ35.
Sure, but the question was installing a VQ35 into an NM35 and using all the turboey bits
The turbine housing is way too small, and the manifold studs will need to be swapped around... And the gearbox won't bolt up, and the starter is in the wrong spot...
Then the cams won't work... and the real drama's begin.
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
