Has anyone seen this on an rb before?
Mine has randomly let go between cylinders 3-4, oil is clean and pressure is spot on, not running hot at all, coolant is clean.
It just started running All of a sudden really rough, and after a comp test, cyl 3 and 4 have nothing, sooty plugs and that's it, every thing else seems fine.
Sounds like the seal between 3 and 4 is compromised, there will be no water or oil mixing issues, simply no compression if dead on right between the cylinders.
Good way to check is pull a spark plug out of one of the 2 failed cylinders, leave the other one in the other failed cylinder, turn over the engine by hand, when the cylinder that failed with the sparkplug fitted is in the compression stroke you will hear a hissing into the cylinder without the spark plug.
Same will happen if you swap the sparkplugs the other way around, whichever cylinder is going into compression with the spark plug fitted will leak out into the failed cylinder next to it without the spark plug.
Edited by GTRPSI
Only runs up to 8psi, standard r33 tune. Standard timing, it is an rb30/25 running the stock 370cc injectors and ecu, afr's are spot on at 14.7 @ cruise and up to 11.7 @ full boost,
Components look flat under a straight edge but may have to look closer with feeler gauges, maybe get some bits milled/surfaced.
Might be an excuse to build a full angry engine!
Edited by nicksamaniac
Sure am, even had it on the Dyno to check it! The afm goes over 5v at around 11psi boost, it's at 4.89v at 8psi, so that's as hard as I can run it.
I have a set of sard 700cc injectors but am waiting/saving for a power fc.
People say it can't be done but if you think about it it's the same as winding up boost on a stock 25.
Its only 500cc or 500ml capacity Extra.
Lol that's the craziest thing I've heard. just Because it runs Ok at 8psi on the dyno doesn't mean that in the real world it might not boost spike and max your afm out and cause detonation. Which is exactly what's happened.
500cc more is a biy more then winding the boost up. The comp ratio has changed. The airflow characteristics have changed all throughout the load and rev range. It's never going to work safely on a stock 33 ecu. Do yourself a favor and get the head checked. Gasket replaced and put a tunable ecu in it
Boost spike? With a 4 psi spring in a 50mm gate, bleeding off to get a MAX of 8 psi, with the boost controller at full bleed.
Funny how I've been driving on this setup for 22000km.
I actually have an answer now, head is not flat, out of spec over the length, explains why it went between 3-4.
Actually, it's not all as silly as it sounds. The load is measured by the AFM, so the fuelling will be correct at pretty much all points, and where it is wrong, it will be richer than the original fuelling in the 25, so safer (if more wrong!). The timing will probably stil be OK, as the RB25/30 doesn't usually end up with more compression.
I'm not saying it's a great idea, but the ECU at least is able to do it. If it was an olde schoole MAP sensored ECU, then you'd have good reason to call foul.
^ +1. The capacity increase VS the amount of boost these engines can put up with COULD allow it to run safely. The fact that the afr's have been checked should confirm the state of tune is sufficient to support the load/demand of the setup.
A bit unlucky it let go. Good on ya for chucking it together and having a go.
To many people spend too long thinking about stuff and not enough time doing it and seeing what happens.
  • Like 1
Thanks for the positive reply, most forums only dish out negative stuff and false tech info.
At least I'm doing my own r&d (so to speak) if it doesn't work, at least it's only made/built from spare/leftover parts around the shed and hasn't cost $thousands in the first place.
Probably was always out of spec, it was just removed from a stock n/a rb25 (r32/cefiro) and bolted straight onto an untouched r31 rb30 bottom end. Using a cheap fiber head gasket.
Probably was a good thing I had a nasty gasket as aposed to a mls-r, it probably would of done head/block damage in the long run instead of chewing out the gasket.
I'll get it milled, fit some better valve springs (bin the non turbo ones)
and screw it down with a good gasket.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
