For sale are some quality parts I consider surplus after a few changes in direction....
1. GT2860-7's with 400km's travelled, 2nd hand cam (exh) broke and bent some valves, rebuilt engine to higher hp spec's than the -7's.
In excellent condition, includes garrett actuators.
Price; $1500.
2. Axxis Hero wheels, 19/9.5 at +22 offset, They have almost new(400km) 265/30/19 Kumho Ku31's , the wheel pictured has the worst rash,
The same wheels in my avatar, Selling due to finding some LMGT1's.
Price; $1500.
3. R33 GTR specific Apexi PFC with hand controller.
Price; $650.
4. Ti front pipe, unknown brand, Learnt the hard way R34 pipes are indeed longer than the R32 & 33's
Pics indicate its good condition.
Price; $500.
5. Kakimoto Hyper Fullmega N1 cat back exhaust in good condition, front section heat wrapped.
Price; $350.
6. CES dump's and matching front pipe, includes adaptors for lambda sensors.
Price; $300.
7. Jjr coil pac's, where replaced with Splitfires which didn't change the issue.
Price; $200.
8. Std R33 RB26 injectors.
Price; $200
9. Std R33 RB26 Crank balancer/pulley, has travelled 400km, upgrading to crank trigger set up.
Price; $200.
10. Chinese?? GTR hard pipe kit...silicon joiners and hose clamps included.
Price; $150
11. 3in Hi flow cat in good condition.
Price; $75
12. Have a std size R33 RB26 crank,
Good condition.
Price; $250
Misc...RB26 rod's and pistons, also a sleeved block which is cracked through to the water jackets from the head studs.
Offers considered....
Happy to post at buyers expense, pick up is fine too....
PM me on here or text to 0418630718.
Cheer's Glen.
Pm's replied...
Also have 2 intercooler's, 1 from an R33 GTR and the other from an R34 GTR, relatively good condition, pic's if your interested.
R33 int- $200
R34 int- $250
Gday...
The Ti pipe is 70x2 into 80mm, it will fit under the car no problems but is a fraction longer, off the shelf cat back systems will no longer fit without mods...
Hard pipe kit SOLD and dispatched.
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
