Buy a very large syringe and some small bore PVC hose.
If the Nistuned ECU is set up to be an RB25DET ECU, then you can put any maps into it you like. You need a programmer to put the actual ECU firmware onto it (the first time, or to change it for another different engine application), not to change maps. As said above - all the Nistune base maps are freely available in the ROM pack.
If that is not an optical illusion then they do not look like the same length. The closer one has longer splines. But here's the rub. You say it has an aftermarket mechanical diff in it? Well, when you buy a Nismo LSD you get 2x new stub axles to go with it, because the Nismo mechs are not intended to work with the original unequal length VLSD stubs.
https://www.gtr-registry.com/en-nissan-skyline-r31.php
I'd be re-doing the head gasket check(Combustion leak), can be very subtle and given how long it takes to overheat, likely a small break in the head gasket. Agree the gktech fan needs to go but assuming you are in brizzy it should hold up to 25degree weather. Out of the 5 or so times I've had this problem, only once was I lucky enough to have a stuck thermostat. The rest, pull the head off fun times. I hope for you this is a lucky one
