Hi guys,
I was wondering if someone in the Sydney area can help me out. I'm currently looking at installing 2860-5 to my car. I have purchased everything that I need to do this.
The drama I'm having now is the thought of going straight to a single gt35r or simular. I really want to make sure I will be happy with the /5's. can anyone in Sydney take me for a spin? (you drive of course) so I can be sure I am doing the right thing :pi really want to feel how the power is delivered. No point on going to all this effort for disappointment when I could have done it another way in the first place.
Can meet at a maccas or servo of wherever required. Would really appreciate it!
  • Replies 50
What capacity is your motor?
What kinda power are you chasing?
What fuel will be used?
Driven 5's on a 2.8L and hold the faaark on after 4K on a 2.6L id say itd take around the 5K+ zone before things get exciting ;)
Andy i have the t517z 10cm on mine and i can show you that, ive gone straight to a gtx3076r (sitting next to me right now <3) because unless you plan on building your engine the gt35 is too big and lagy for the standard internal 2.6 You can push the gtx3076r to 400+kw on e85 and anything past that on a standard block and your asking for trouble. Ill only have these turbos on the car for the next few weeks then its all coming off for the single.
Hey mate, keeping it a 2.6 for now. Chasing 350kw+ on e85. Stock bottom end.
Yea mate, pm me your number. Would love to come around and check it out. About due for a catch up anyhow. I'm going to keep stock internals for now and see how far we can push it. I may look at a rb26/30 if or when she blows.
If your chasing 400, get ready for disappointment...
Hey may not make those numbers... Even on e85. But it would be as responsive as hell.
No, sorry, -5s will make it on e85 easy if everything is sorted. Heaps of examples of it in the 400kw thread.
The gtx3076, I don't think will flow 400kw except when the setup is tip top and turbo is all in. I dunno why you'd go that route over the 6262 which seems to be more popular these days.
Not many people run gt30 singles on 26s.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
