  • Replies 293
Messed around with a few things today, got the dash grills in. Unblocked and lined up the washer jets. Reattached my car charger (at a new angle so I can actually fit stuff in it). Put the body kit screws back on. Tomorow will be splash guard on under tray on and hook up the amp and have it on a switch
