Hey guys got a problem my car didn't make the power I think it should have made.
Rb25det s1
Gt3076r .63 rear
High mount manifold
50mm wast gate with 14psi spring
800cc injectors
Bosh 044 fuel pump
Turbo smart fpr
Upgraded coil packs
Greddy copy intake.
3inch straight exhaust
Blitz dual solenoid boost controller
Microtech Lt12
I only made 296rwhp was the best run of the day at 18 psi
Seems low compared to others iv seen on this site?
Also I did notice that boost drops off from 18 nearly back to 14 at the top. Fuel and air sitting on about 11.6 . Any thoughts?
Edited by DriftSquad
You will need a stiffer spring in the gate imo, and the .63 rear won't be helping things.
Can you get us some pics of your setup? Was the exhaust dropped on the dyno?
I didn't get the chart as I was not happy with the tune. Tuning was done at Godzilla motor sport. On his dynonamics awd dyno
and tell them to send you the tune file
I have a feeling the tune was shit house, also because it's a microtech lt12.. they're so clunky to tune with.. 2x tables to do essentially a single table can do.
I'll ask him to email it to me. Marks pretty good tuner. I mean it is a microguess lt12...
We had to pull some timing cuz she was pinging on boost. He said he thinks the .63 housing is to small
Not sure it's just a stainless manifold with gate mounted to it. The power I Made is not much better then a standard rb with a tune..
If you had bought a decent standalone and left the FFP, stainless manifold, fpr, boost controller etc off the list, you will have had more money to spend on finding the issue on the dyno.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
