I saw 900 degree manifold temps regularly at the track, all with a beanie on. The car has done 6 hard track days and daily driving for many years without issue.
As long as the CHRA is water cooled you should be fine.
Thanks for clearing it up. When I baught my beanie off hpiab they said remove it after hard driving and whilst racing to reduce the risk of damage to bearings. I thought why sell me that if it Can damage the turbo.
Whats the go with HPC? when I had my manifold and housing done I really couldn't tell the difference, I mean even if temps are down
1000c to 800c for example, its still bloody hot, retaining that extra heat might even cause the manifold to crack from the inside
out?? Maybe on a track car it sounds plausible but on a street car things wouldn't get hot enough??
Aparently beanies can lead to internal bearing damage if left on and raced with. No idea how. Hpc coating increases thermal efficiency in the turbo which leads to better response. Plus if you hpc coat it silver the chicks will flock... hard. But in all seriousness when I do go a steampipe manifold ill be hpc coating the manifold and turbo housing. Looks good, doesn't get that rusted look from heat, serves a purpose.
This. Just do it and rest assured it's an asset to your build. I've always HPC coated my exhaust components (if the wallet permitted I'd do the entire system ;) ) but my turbo manifold, ex housing and dump pipe/wastegate plumb is all coated. Granted, it is still hot (but greatly reduced) and you can feel that under the engine bay... but consider this... what would it be like without it? Whilst off, definitely beneficial if you can afford it.
Edited by Reflector
But he already has a beanie, so it's a total waste of cash. I would only ever recommend it for mild steel exhausts to prolong their (short) life.
DEI Beanie and DEI Ti wrap the dump (for stainless) is the best shield against heat I have found so far, and I have used most other styles of heat barriers.
Im not saying it for heat shielding. im saying to hpc coat it to retain the heat inside the turbo exhaust to improve thermal efficiency. Yes it helps shield heat but im aiming at the heat retention in the turbo. i was running a turbo beanie untill a poorly made oil line burst and filled it full of oil. now it wont stop smoking. its like i have bob marley under my bonnet.
Hmm iv hit a wall! I bought what I was told was a gt3076 .82 rear but it does not seem to fit the wheel?!?
Here are some pics. What have a bought and maybe my turbo isn't what it should be?!?
Do yourself a favour and ignore what the tag on the core says for a moment... Measure the turbine at its largest diameter and see if its 60mm or 56.5mm.
ARTZ had a turbo from a reputable resaler which was labelled a 3071, but when we measured up it had a 56.5mm turbine and a 76mm T04S compressor. It was more likely they had rebuilt it and simply neglected to update the tag. Or built a custom turbo from whatever they had around... Who knows.
Its possible that its for a 35R, as the housings are identical on the outside. You should still measure your turbine though.
Once you measure the turbine you will know if you A: have the wrong turbo for that housing, or B: have the wrong housing for that turbo.
You must measure first.
Edited by GTScotT
True: the photo's clearly show its wrong. SO, the task is now to work out what housing he actually needs and who's responsibility the wrong housing is.
In A: the seller did nothing wrong and OP needs to wear it or ask nicely to return, in B: seller needs to give OP a refund as he misrepresented the product.
Edited by GTScotT
Highly likely a EWG housing for a GT3582R , probably the easiest thing is to measure the ID of the housing and if it comes out a little over 61mm that sort of gives the game away . A GT30 turbine from memory measures ~ 54.9mm at the exducer (outlet diameter) so a matching housing would be that plus clearance .
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
