9.8:1 says google for e85.
Vq35 stock ecu and add/ subtract 25% fuel, sadly I know from experience.
So, if it had an infinite range, on e85 it would still be able to trim fuel to lambda, the sensor would output volts that the ecu sees as 14.7, and the real afr would be 9.8:1?
octane is octane. it's a way of measuring any fuel. LPG has an octane rating too.
Indeed!! Many people think octane or RON is some sort of fuel quality figure or fuel energy density figure.
It is not, it is just an indication of the fuel's resistance to detonation.
Both LPG and E85, have octane ratings above 100, but they return reduced fuel economy.
Edited by sonicii
If the ECU were able to adjust, would the stock injectors be able to keep up with 33% increse in fuel demand?
I've tested BP98 Vpower Caltex98 and United P100...from my experience, BP98 works best with better fuel economy than Vpower and Caltex.
BP98 vs P100...not really noticeable but I "feel" that P100 gives me more pull. Economy wise...slightly more with P100 but could just be road conditions..Nowadays I only use BP98 or P100 depending which days I need to get petrol as P100 is usually cheaper.
Did you reset the ecu to clear the long term fuel trims though Colin? Not a good indication if you are just changing for one tank full, plus the fuels would be mixed as the tank wasn't empty.
I would expect less K's to a tank with any e10, there is slightly less energy density.
Hey Scott, I do at least 3-4 full tanks and average it out, and then reset ecu for the new fuel and repeat.
Both my V36 and R34 does better with BP98 as well over the Caltex and VPower...
P100, pulls better and does similar K's to BP98 or just a bit more.
Actually thinking about it, P100 pulls better over Caltex and VPower....comparing to BP maybe same or so...that one I am not too sure considering I use either one.
Recently though I got my V36 tuned with P100 in it...
Do you think mixing BP98 and P100 would be a problem?
Edited by colin.ssc
No, any car can run on ethanol if you have enough overhead on the injectors, or just stick 30% larger injectors in and let the stock ecu work it out. :)
this advice really should come with a disclaimer...*results may vary*
Agreed, if people didn't realise, injector overhead requires you have some form of injector control, eg Osirus cable for the V35.
As I learned in the MoTeC training seminar back in 2004, they use lambda in their ECU software because it's a universal representation of the stoichiometry as opposed to having to remember all the different AFRs for different fuels.
Therefore, a lambda of 1 in an ECU map will translate to the respective stoichiometric AFR for whatever fuel you are using.
That said, not all wideband O2 sensors back then were fit for all fuels, so there were different sensors to suit different fuels. Changing the fuel type meant changing the sensor too.
I'm not sure if that is still the case today.
As far as I can see in the UpRev Osiris software, of what little I've looked at so far, they map in AFR terms.
[Edit: Actually, I think there is a choice for AFR or lambda in the software's preferences for units of measurement. Just looked it up but couldn't confirm since I'm overseas without my Osiris cable!]
Edited by The Max
95-98 ..is there really that much difference? if i can get 95 octane e10 for 1.30$ a litre when 98 is a 1.60 a litre...thats at least a 15$ saving on a full tank of fuel...if i am using a tank a week thats maybe an 800$ a year saving...thats my registration paid....add to that ethanol will help clean your fuel system as well as any additives they put in 98....I don't see the problem except maybe 2kws and a bit less range..and i dont use 15$ worth of fuel in 50kms...
if e10 was the only fuel at the pump, everyone would run it ..but people like choices, this is the MAIN reason we have different fuels...if water was the only drink in the fridge, you would happily drink it but no, go to a servo and there is 4572 different drinks to choose from...why? because peopel like choice...truth is it really makes no difference what pump fuel you run because your car was built for its tolerances in mind......true some fuel might make your car live a little longer, but alot of people couldn't care care less...cars are disposable...
The way I see it, Ithought these vehicles were made ideally for 98RON. Why skimp on the fuel in the first place?
people like choice
end :rant:
95-98 ..is there really that much difference? if i can get 95 octane e10 for 1.30$ a litre when 98 is a 1.60 a litre...thats at least a 15$ saving on a full tank of fuel...add to that ethanol will help clean your fuel system as well as any additives they put in 98....I don't see the problem except maybe 2kws and a bit less range..and i dont use 15$ worth of fuel in 50kms...
if e10 was the only fuel at the pump, everyone would run it ..but people like choices, this is the MAIN reason we have different fuels...if water was the only drink in the fridge, you would happily drink it but no, go to a servo and there is 4572 different drinks to choose from...why? because peopel like choice...truth is it really makes no difference what pump fuel you run because your car was built for its tolerances in mind......just like it doesnt matter what drink you choose from the fridge its going to kill you anyway..
people like choice
Water is better for me than any other beverage. It's not really a fair comparison. Using 95RON as opposed to 98RON isn't recommended for the vehicle and it has nothing to do with choice. I can also choose to scratch my crotch with a cheese grater, or perhaps less severely, wash my car with a scouring pad but that doesn't make any of it a wise choice. You put in what it needs, not what you choose.
A Toyota Yaris is made for 91RON so with the possible exception of slightly better fuel economy (though I wouldn't know for a fact), there'd be no benefit for 98RON.
A V36, on the other hand, is made for 98RON so running 91RON would simply be deemed inappropriate.
The choice we're given is what car we choose to drive and in turn what support we get at the bowser. There's not much choice with the fuel, from my point of view.
Edited by The Max
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
