Hey people,
I currently have an rb20det with;
-Z32 AFM
-GTR 444cc injectors
-Walbro 250lph pump
-VG30 turbo (rb20 wastegate) running 15psi off a boost t
-Intercooler
-Cat back
-Nistune
Currently running around 190rwkw.
Now I have in my head two paths to go down.
1st, I was thinking leaving the vg30 turbs on there (has nil shaft play and blades look fantastic still) and upgrading to an E85 450lph Walbro pump, larger injectors and getting it tuned on E85. With that in mind what size injectors would I be looking at 750's or 1000cc's. 1000's seem massive to me on an rb20 with small to mild mods?
2nd path I was thinking was to go a hypergear hiflow and retune.
With either option i'm going to upgrade dump pipe and electronic boost controller.
Just after some opinions on which option would be a better bang for my back upgrade for the lack of a better term.
Cheers Steve.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/
Keep the stock manifold.
As the ceramic turbos are untested on E85 I wouldn't risk it. The theory is sound.. It should be cooler, but theres no guarantee the added power won't push the heat back up anyway.
I also agree a highflow to an appropriate size will yield better and more reliable results.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7197866
no real point of running e85 unless you want to boost the shit out of it. You won't get as much out of it at 15psi. the VG30 turbo won't hold up to that for long so I'd suggest a HG highflow and a retune on 98 for now, save the injectors for later then switch to e85
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7197935
With respect to whether e85 will make life easier on a ceramic turbo....it might, but I wouldn't count on it. The real killer is not heat, it's shaft speed. The mechanical forces acting on the bond between the ceramic and the shaft and internally in the blades rises at some high power of the rpm. Spin it too fast, and it go poof. Fast is either more air or more boost (just look at a compressor map and see why) and for more power (on e85 even) you need more air. With a fixed restriction downstream (the engine) the only way to get more air is more boost. So you're stuffed anyway.
Decision made above is a good one.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7198216
E85 doesnt necessarily mean more boost.
The main benefit is actually the resistance to detonation
I think you should go the e85 path, big pump injectors and tune. Your tuner will be able to add a forkload more timing across the board and make your car drive more fun.
If you go the larger turbo route you'll definately get more lag, less time near boost in a street car and not enjoy it as much.
Or since you didnt mention dump pipe go kando td05 and wind up the boost :-)
My 2c worth
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7198416
Exactly right, you can either add timing, boost or both. I chose boost and it works very well also.
I figured pushing the turbo hard was better than relying on the rods to take extra load, seeing they are stock.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7199989
I thought about it for a bit and came up with if I push the vg on e85 and it lets go I'm up for a turbo anyway.
So I'll get the ss1 in tuned and running and then look at e85 once I'm happy with how the cars going at that point in time.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7200639
I'd just get bigger injectors / pump and get it all tuned at once with the ss1. The money you'll spend on the re-tune you could have almost done the fuel system.
I just sold brand new unopened id1000's for $500 and bought a walbro 400lph new for $190.
A tune will usually set you back $500-$600
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7201463
For the sake of starting a new thread,
Just sussing out some more options, one of my current injectors is leaking (replaced o-rings and no difference, i assume its cracked maybe?). Im going to upgrade pump and injectors now as well as the SS1.
Basically question is should I just keep the resistor pack and stay with low imp GTR injectors, or revert back to the standard RB20 setup and look for some high imp injectors?
I've noticed there's a sale on RHD at the moment on SARD 800cc's too.
Edit: Also going to pick up a new Walbro pump, if I get the E85 compatible pump will it be safe to use 98 for a while and then when im ready switch to E85 later on? Or is it designed solely for E85?
Edited by Tonks
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7208728
Go with deastchwerks, they're bosch ev14s, high impedance and drop in fit for the RB20
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb20det/1989-94-rb20det
Edited by Missileman
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7208776
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
