Hmmm another thread hijack haha lol, well quick update, going in again on Wednesday, got all the fuel out, ran some fuel with injector cleaner just to clean things up a little, tomorrow hopefully going to drop in a set of new spark plugs BCPR7ES-11, new fuel filter and a quick Liqui Moly De-Carb, a fresh tank of BP 98 and see how that goes, hopefully with the fresh fuel with no additives and a colder plug the NOX should lower and pass, will let use know how I go, thanks.
NOX level too high again, this time it was 1.30 max it's allowed is .63, from everywhere I've read is high combustion temperature/car running too lean.
So tomorrow I'm gonna make a pipe to sit where the air flow meter sits and pump it up with 20psi of air and check for a air leak, thats all I can really think of it being, and also check my fuel pressure incase my fuel pump is pooping itself causing it to lean out, and far out with Australian restrictions lol, I wish I was in America right now because CRC has a product called G2P (Guaranteed to pass) that you put in you're fuel and somehow it just kills all of the levels for a emissions test lol.
As far as the THX and Co2 is concerned its way below the allowable limit, THX is .20 and CO2 is 0.02 this time, gotta wait till next Wednesday again ffs.
That sucks so bad! I read somewhere ages ago that retarding timing and raising idle and adding fuel pressure will help reduce NoX.... Not 100% sure though.
Good luck next time!
In that case would you like to contribute to my Bigger Turbo fund :-D haha lol, yeah man trust me you don't want to be in this position it sucks, plus its my daily, and now the car I have been driving is just too low and the seating is low aswell so its not doing me any favors to my stuffed knee, pain from everywhere haha lol.
  • 3 weeks later...
Well today was my 6th attempt and still no good, this time the THC was 0.39 Nox was 1.19 and CO was 2.5, there was a silvery/green r34 infront of mine and he passed on his 4th go, my dad took the car today as I couldn't make it, and he didn't get me his number, if anyone knows him or if you're reading this could you please please please inbox me asap, my rego is getting cancelled on Friday ffs, I'm so sick of this, its been 8 weeks now, this time I put in a mixture of vortex 98 and E85 making it E30 and still nothing, the testing guy apparently told my old man "this cars being used as a racing car or something?" wtf was that meant to mean, thanks.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
