R33 Rb25Det Series 1 Skyline Cam Covers Brisbane
Because an r33 speedo bolts straight in and doesn’t require butchering the wiring
A speedo corrector module has to be the simplest thing. Why anyone would consider any alternative is beyond me. You could even knock one up yourself with an arduino in an afternoon.
I have no idea what the power steering control module is on a non-HICAS car because I've never seen one. But it is a fair bet that is essentially the same thing as on any other Nissan of the period with variable PS. So, Maximas, that sort of thing. It will pick up the ECU's speed signal off the "bus" (there's not really a bus - any consumers of the VSS are all just connected to that output on the ECU). The output should (most likely) be a PWM signal to give you an effective average voltage between the minimum and maximum values. You could possibly look at the HICAS part of the R32 manual to see what that range is likely to be (for non-HICAS, as it should be about the same).
Thank you for the info! Did you get a 33 gearbox speed sensor to have your speedometer to work? Does the Speedo work but not accurate?
Took me a while to answer that.... Funny thing is, the across the river neighbour did put in an airstrip, built a hanger, and buy a cessna, because strangely they aren't allowed to build a house on the property but there is no problem building an airport terminal They've used in 3 times, once for an attempted landing where they misjudged a little, aborted and missed the trees by so little that new underwear was required. Second time the landing stuck, then a few weeks later the plane left and never returned, so I don't think aircraft noise is going to be an issue. Funny looking back through the last few posts too, I've spent a heap of time lately redoing the roads and drains so I guess it is a 2 yearly thing to add to the calendar. Those big drains did overflow in the rain about a month ago so that is pretty disheartening....just a reminder that you can't stop nature I guess.
