After seeing some dyno sheets of the hypergear atr43ss2 i think it'll be a bit laggy for me.
Does anyone have any opinions in terms of response on INTERNALLY GATED kinugawa td06-20g-10cm and hypergears atr43ss1/pu or their op6 highflows?
I've got so many people telling me mixed sht I just want some opinions which will be best for the street. I want full boost as EARLY as possible and want to be around the 280rwkw mark.
Keeping in mind the td06 is $500 cheaper too
Rb25det fresh forged
E85
Tomei 256 cams
Supporting mods
Std manifold / int gate
Cheers
https://www.sau.com.au/forums/topic/439786-kinugawa-td06-20g-10cm-vs-atr43ss1/
The two turbos are not comparable.
280rwkw maximum response on E85 a 2IU highflow from hypergear will get you there.
Why aren't they comparable? How much bigger is the td06? 280 was on the low side, ideally I'd want a turbo capable of 300awkw but not if it'll sacrifice too much street ability
An SS1 is comparable to a garrett GT28 in size, a TD06 is comparable to a GT30 in size. I trust you know the difference between a 28 and a 30, its fairly major.
You also will struggle to see 300awkw from a TD06 20G, which we have covered recently in another thread. In fact, the forum arms you with more than enough information to form your own opinion on the topic within an hours reading. The Hypergear thread is not only indexed with SS1 results but ALSO TD06 based results.
Go to the hypergear thread and fill your cup.
Edited by GTScotT
  • Like 1
Do you really consider full boost by 3700 as laggy?
Its not 'laggy' but i think its a bit big for what i want. For a street car that barely sees redline and seeing as I'd be happy with 270-280kw on e85 I think it's overkill.
Could just go smaller rear housing I guess
I've found a garrett bb turbo that's probably a little on the big side but it should do the job. Priced well and internal gate. Made 273kw at 16psi on 95 no cams. Makes 100kw at 3000rpm which seems good
Money is also a big factor seeing as this has all blown out 10 times what I expected.
Ill do a build up thread
Std high flow makes 100kws at 3000RPMs and maxing out at 320rwkws on E85. Note this turbo hit 20psi at 3400RPMs, there isn't many turbos out there can do this without chocking the engine tho. Pump 98 fuel usually makes 40kws less. It is cheaper then what cost you to buy a TD06, after testing all this TD06 based turbos, I'm fairly sure it is far more responsive then any thing based in a 10cm turbine and makes more power internally gated.
Added 270214:
labeled dyno reading from 21U high flow internally gated on Stock manifold E85 (take 40kws off for P98 result)
my tdo6 almost makes 100kws at 3000rpm ( well 90 but at least my graph is clear..)..and makes more torque at 3k than anything you just posted Stao...it is Externally gated though, internal gate tdo6s are fail
Give your Hypergear a run for its money anyday :P....
its also for sale..full bolton kit....buy it ;)
I would if it was internal gate.
I'm still trying to get my head around the hypergear range. What's bigger, the ss1 or the op6 highflow? What is the ss1pu? What physically LOOKS bigger? Stealth is also a contributing factor as I'm in big trouble if I need to go to the pits with a 25 on e85 in my 32
why not feed your highflowed RB25 turbo with E85?
isn't it already installed on your motor?
That turbo is being replaced. It's an rb20 turbo and it's tired. Obviously if I already had a rb25 highflow I could use, I'd use it.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
