When you arrive at your first meet, make sure you segregate yourself by race and religious belief, the Mexican will approach you, compliment your vehicle and ask you what you are running under there. At this point don’t be too concerned he isn’t gonna hit you for slips as he is going legit and trying to get on the NIRA circuit. So reply with some sporty banter and embrace him with a mafia spec hug – kiss on the cheek is probs too soon ONLY ON THIS OCCASION .
During the drag race, don’t hit the 100 shot of nos too early, you don’t want the welds to blow on the intake or the floor to fall out too early. You want the floor to drop just as you cross the finish line so if you happen to be racing a red RX7 he can’t activate his nos at this stage.
If police happen to raid the meet, make sure you pick up the owner of the red RX7 if you see him on the street, this is your way into SAU. You will be invited to a post meet party to play some GT2 and some coronas. Don’t bang his sister just yet.
Exchange snap chat names with her, screen shot nudes and post to SAU. As the grand wizard is an RX7 owner he won’t see nudes of his sister on SAU.
If you are going to take her out one night, make sure it’s a Cuban restaurant called cha cha cha.
At this point in time, I am hoping you are not a cop, as we run a great racket here at SAU which helps us pay for the shit under the bonnet of all these cars. I will let you in on a secret its cheap chinese DVD players worth about $20 a pop, hence why everything uses china turbos and knock off rota wheels as gee the money is good but not legit parts good.
This should give you a good feel of the place and enjoy your stay.
  • Like 2
https://www.sau.com.au/forums/topic/440125-new-car/#findComment-7220826
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
