Hey guys, a little dilemma...
R34GTT, Precision 5558 / 0.63 a/r, 40mm gate off housing, plumb-back 3" exhaust system, Power FC, usual support mods, stock coils, stock BOV, 100 cell Lobokka metal high flow cat, 100% street car. 286rwkw at 18-16psi by JEM with old Nistune. Changed to Power FC I picked up cheap to get retune and 'better' ecu / tunability.
Unigroup say there is a restriction in my exhaust system - the cat itself because it wouldn't make any more power going from 20psi to 23psi on 98 fuel. Power actually dropped, made a crappy 270rwkw at 20psi and very retarded timing! Recommended to change cat/ de cat with a stock shell outside etc; Current state is a very safe but very retarded tune (timing) on power FC till I get cat sorted.
Options:
http://justjap.com/index.php/engine/exhaust/catco-3-high-flow-catalytic-converter-nissan-type-3.html - highflow cat
http://justjap.com/index.php/engine/exhaust/x-force-3-stainless-high-flow-cat-nissan-type-3.html - highflow cat
http://justjap.com/index.php/engine/exhaust/jjr-stainless-racing-de-cat-pipe-nissan-r34-gt-gt-t-skyline.html - decat pipe / illegal
Please advise what to do, I already have a eGay 100 cell Loboka metal cat fitted (3" entry/exit) and that's a restriction I'm told? What is the most cost-effective way, second hand is ok.
Have read most of the cat threads, too many mixed opinions to decide, my current cat was actually bought based on these forums..
Edited by rondofj
https://www.sau.com.au/forums/topic/440825-restriction-in-the-exhaust/
Most recommended as far as my reading goes is the Venom 100cell metal 5in which I have. But you will definitely get better flow with a decat look alike if you are prepared to take the risk. I am making 314 AWKW with a GT3540 and a three inch exhaust right through. Are you sure your muffler doesn't step down to 2.5in as a lot of big brand Jap ones do? Can you get comparative flow numbers for the Loboka (never heard of it TBH) and the Venom?
Don't know the flow numbers mate, and its got two names Bokka and Loboka if you ebay it..so dodgy as, but surprisingly good build quality and the metal internals have held 2 years of hard driving. Exhaust system is 3" all the way with stock looking oval mid muffler but that is seemingly 3" as well.
Did yavus drop the exhaust on the dyno?
^^ this. How can they say the cat is a restriction without dropping the exhaust in sections?
I ran 310kw with the same cat, I don't think it would be holding you back too much, but who knows...
The difference "could" be down to the different dynos. Does your car feel slower?
Strange because Unigroup seems to have a very good reputation (although anyone can have an off day).
Maybe your second hand PFC is defective?
Did you measure the back pressure? I did a rough measure on mine by making a fitting to go in the O2 sensor hole connected to my boost gauge (not running an O2 sensor).
Lol I dont even know how to measure back pressure, and no, my PFC is sweet, as confirmed by Mark from Unigroup. He said mine was one of not many cars to be very clean with no issues apart from the bloody exhaust. And they're adamant it is the exhaust because it has so many variables and most cars they've tuned which were down on power was found to have a restrictive exhaust, notably the cat etc;
Mine was overheating and just wouldnt make power even with higher boost, power actually dropped, and according to Yavuz thats an exhaust restriction- intercoolers doin a brilliant job, confirmed..
And yes it does feel significantly slower/retarded timing from driving feel. Yavuz confirmed that timing has been retarded a fair bit by Mark.
The cat might also just be failing? Depending on how hot etc, not all CATs last forever.
I mean one brand had a LOT of failures in the latter half of last year, so anything could've happened... But you kinda do need to drop the exhaust to work that out :merli:
Hell it might even be the exhaust itself, all that gets confirmed by taking a couple bolts off - Is it a Jap one?
Ok my exhaust- custom 3' dump from back of turbo to cat, wastegate welded to turbine housing and plumbed back to dump just before cat. 100 cell gay metal cat 3' in/out and 5' body/ bokka brand. 3' pipe from cat to oval mid-muffler. 3' pipe from mid-muffler to X-force 3' straight through
oval muffler.
Gay bokka. lol.
It is a 100 cell cat with a 5 inch body, the metal cats are all much the same construction wise, there is no way it would be a restriction unless the core has shifted, which would be fairly obvious if you dropped two bolts.
I still think it's the cas, but out of interest, do you have a pic of the gate etc?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
