Tyres diff all same, stock ecu and nistune I was doing 100km/h in 5th at 3000rpms, PFC now I'm doing 2600rpms -normal motorway cruising. And no gay 22" rims, running 18" RAYs wheels
so how do I know what tyres you have............
If it's 2600 vs 3000, then at 7000 indicated it should be really revving to 8000, if the error remains linear.
The tacho (whether in the ECU or at the tacho itself) is a pulse counter. There is no "voltage" to get wrong. If it's counting pulse wrongly at the ECU, then that doesn't bode well for all sorts of things. After all....the whole point of the ECU is to know exactly how fast the engine is turning over, no?
I would be looking into this problem as a matter of some concern. Do not sweep under the carpet.
i guess i offered that as a way he could check his speedo/rpm gauge calibration...what are you the f**kin forum police?
Settle down Bro! Are you having a bad day?
I guess I didn't guess that by your post.
Going on to the dyno to check it would be an option,, as would using an automotive multimeter with tacho function to compare stock gauge (you could buy a multimeter instead of paying for the dyno hire)
But that's not really the issue. The fact that it changed by only changing ecu implies to me that there might be a problem.
my speedo is currently having problems...i fix it by bashing it(not recommended..breaks windscreen).....mine doesn't like going above 60km/h until its warmed up...but i'm curious as to wether its his RPM or speedo that is incorrect....the speedo drive/sender is off the gearbox right? and the rpm is signal. It could be just a coincidence that it happened when ecu's changed?
I'm not guessing wildly
Are you a mechanic superben ?
Do you even work on cars your self or just pay people to do the work
Is has been proven time and time again larger cams than std always shift the powerband higher on any car
Yes you will gain power up top but is it worth the loss down low which is up to owner and driving style choice and purpose
Yes you can get the manifold runners tapped and check the egt and engine backpressure under load on the dyno to confirm but the price to get that all done you could have gone to a new rear housing but do as you like it's your money and time
Yes I do ALL of the work on my car . Amongst other things I wired up the ls coils, put the rb30 bottom end in, do all tuning and recently put some type b cams in. Not that that is particularly relevant.
You are guessing as to how much the power band will shift. Typically better cams will have more lift which will create more flow all over and therfore increase power in all parts of the Rev range, making the shift to the right not as bad as you would imagine.
Have you put in cams? Not that I care.
Yes I've replaced plenty of cams and a mechanic by trade so work on cars day in day out
I ve driven a few cars before and after performance cams are fitted and yes you won't notice the power loss if you have a heavy foot and drive in the powerband of the new cams everyday but most people just give it a squirt here and there and ain't alway revving above 4000rpm
dailying it and cruising will be where you feel and notice the power loss downlow between std cams and performace cams
Ok. As per any mod it comes down to personal situation and preference.
Just to clarify it is the duration that shifts the power band.
The extra lift increases flow all over.
I was saying you were guessing at the 50kw loss at 4000rpm. I wasn't arguing the potential of a loss somewhere.
I also changed turbo, and put on water injection, at the same time as the cams so can't make a direct comparison on the loss, but for reference from an older thread
my car has a different turbo setup but thought i would gilve ,my 2 cents,
found with stock cams my car was making 321awkw and then with poncams 260 9.15's went up to 344awkw, boost was came on sooner with more midrange and topend torque/power, was quite happy with the results,
will be good to see the setups you guys have and see the differences in power with/without cams,
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
