Hey there. I know this has probably been discussed many times before but I would like a bit of feed back please :).
I have a 32 GTR that i use for time attack and sprint days. Recently I just got a wheel alignment and corner balance done and the car now has some extreme over steer happening. So much so that I can barely put any power down in a corner. This brings up my question. What is the ideal track setup for a 32 gtr with street tyres (Federal RSR).??
My set up is: HKS Hipermax IV coilovers.
Adjustable front camber arms
Adjustable front castor arms
Adjustable rear camber arms
Hicas lock bar.
Run about negative 4.2 degrees of camber and 6-7 degrees of castor up front
Rear is about negative 2degrees camber and neautral toe setup.
Thanks in advance. Emilio
What's your budget ?
How good do you want it to handle ?
4.2deg is to much on any tyre, about 3-3.2 is good
Is your rear sway bar adjustable ?
Soften the rear shocks and sway bar a bit and see what happens
Personally I like the race spec Teins or Bilstien
  • Like 1
If the alignment caused problems, get that undone. Around -3 camber is what you'd use for R-specs, so is too much for S-specs like RSRs. I'd start with -2 and see how that goes. Measure the temperature across the tread inside to outside to see if its even. 6-7 castor is supposed to feel great but you'll destroy your upper control arm bushes pretty quickly... -2 camber on the rear is probably too much as well. If you can, post full alignment specs before and after.
R32 attessa sucks balls in stock form - too much power oversteer. Get an attessa tweaker if you dont have one already.
Ahh yes that's right RSRs are an S compound, 2/2.5 on front
Rear depends on suspension bushes use, you need more for rubber then you do for rose joints
As for the Attessa, get the tweaker as Mr Stabby says and do the transfer case mod using the 33 preload setting
The rear diff has recently been done and the front was pulled apart and checked etc when the motor was built. About 6 months ago. Basically I use to run about -2.5 camber in the front and -1.5 in the rear. But I was having some under steer issues. So I took it to my alignment guy and he put in all this negative
Camber up front so it could turn in better.
The car turns in great now but it's like the rear just can't keep up. It just slides around like nothing
also I would go less camber at the rear too, I only run 1.5 and that is on semis not street tyres. A little toe in at the rear (1mm) is will also reduce oversteer
When you say extreme oversteer, when does it happen? turning into a corner, mid corner or on throttle application on the way out. How much power do you have, and do you have any diff or transfer case/attessa controller mods?
Well I was running about 430awhp before the alignment and had no issues with putting power down. But ever since I now backed it off to 300awhp and it still does it.
I Know it may be hard to believe but it happens on turn in if I turn in sharply the rear comes around sliding and if I even apply the throttle a little bit more than coasting midway through corners it kicks out and on exit it basically feels like a drift car... I hate how it feels.
Can you recommend any good places that knows how to set up a 32gtr well Duncan? Thanks a lot
Also before this setup. I had old single height adjustable ohlins coilovers that had f**ked dampeners. Less front camber. Around (-2.5) and I was doing consistent high 58 around qr sprint track and mid 60. Around lakeside. Yesterday I raced at lakeside and ended the day with a 65.5. So I'm litterally 5 seconds slower. :(
R32s understeer a lot, and power oversteer a lot. AFAIK the understeer is due to the weight imbalance, so can be bandaided over but not stopped. Power oversteer is due to the attessa setup which can be cured with an attessa tweaker (and I guess the transfer case mod mentioned by Mick. I havent had it done, but many swear by it).
I have ~400awhp and no problems powering out of the corner. -3 camber on the front -1.25 at the rear, zero toe both ends, castor will be around 4 40 now (stock is 3 40 so what i would have been running last track day, and i believe the nismo kit gives an extra degree), R spec tyres (r888s). IIRC i was running -2 at the front with RSRs, and wasnt that much slower, but r888s suck.
My latest mods on my car to get rid of understeer are: Nismo suspension arm kit, softer front springs, more front ride height (old springs were too short to get to 350mm). Cant wait to try it out.
When they dynoed it did they disconnect the 4WD and if so did they reconnect it, also if the LSD is two way and to tight it can unsettle the rear end on braking turn in which if like me you like to trail brake into corners is fine, if not learn to do it or get a 1.5 way
Bring the front back to 2.5-3deg, closer to 2.5deg given the castor you've got
Rear to 1.5deg and 1mm toe out which will zero out under acceleration but settle the car under braking
Look into some adjustable Whiteline sway bars 24mm front 22mm rear
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
