Is this catch can going to be big enough for my setup welding two -12 fittings on it one in middle and one at bottom and 2 lines from yhat running to top of sump.
Its a split tank that was already on the car it has window washers and oil the other side as you can see .
Fitted my greedy oil cooler on drivers side today had to do a little modification to mounting bracket because i no longer have stock intercooler ,still need to fit up all the lines I had to remove stock bovs
Now in the instructions for the kit it has trust bovs fitted the stock bovs will not fit with the cooler I yhat location seen as though im running a single turbo do I need 2 bovs ? Or just fit 1 in its place if so what type im not into the wanky bov noise .....
I got the stock bovs to fit but outlet pipe sits abit low and inner guard fouls on it cant win ha ha
You only really need to drain it to the sump if you're going to be doing some circuit work. In that case two -12 breathers of the cam covers to the top of the can and either one -8 or bigger drain at the bottom of the can to the top of the sump. If you want to let the crankcase vent from the sump you can add a second line from the top of the sump to the top of the can. Even if you don't plan to do track work I'd be welding all of the extra fittings to the catch can and sump while it's apart so if the day does come where you need them it's an easy job
Also keep in mind if the car will be doing a lot of street k's the drain is going to mean more frequent oil changes due to all the condensation on short trips.
  • 3 weeks later...
Hey guys been very busy with my new buisiness but head is complete sitting in nz ready to send to rob amd my bottom end is also complete rob is just waiting for head
With fuel setup is a 2.5 litre catch can good enough for my powrr figure with 2 bosch 044s ex and 1 internal ?
Rob has fitted 2 -12 fittings to sump so I can run one to bottom of catch can and one to middle of catch can and I already have my 2 -10 lines running from top of catch can to each rocker cover
The size of of the surge tank will have have no impact on how much power the fuel system is capable of,it is only going to effect the surge resistance of it.
Having said that I would say it will be fine. You can get away with no surge tank depending on fuel tank level.
Can't wait to see this run soon!
Ok im noe up to the stage of doing fuel setup and new electronic gauges what are some good gauges to purchase that are well priced Im looking at removing the stock ones in the centre of the dash and replacing with new ones well 2 of them anyways
Problem with small capacity surge tanks is they heat soak quickly, my custom one is 8.5ltr and I am looking into a new bigger one as it starts to heat soak fairly quick
If not track car twin intank it with either 044s or Walbro E85 pumps and carry 1/2 tank min for track use and you won't have an issue
Breathing from the sump is ok for a street car but if you do it for a track car the catch can will quiet quickly over fill and make a mess of your engine bay, especially if you have breathers in the can it self, run a line from the bottom of the catch can to sump by all means but put a one way valve in it to allow oil in to sump but not vise versa
Better off having the return from the rail going straight back to the main tank not into the surge.
2.6ltr is fine if you do it this way, you just have to make sure the intank pump/s out flow the main pumps
That's the same sort of useage I'm doing, so no 2.6 will heat soak quiet quickly and you be pumping heated fuel into the engine, 2 x 044s will turn the fuel around a lot faster from the engine then the 1 044 intank can flush the heated fuel from the surge tank
Should do as there is no pressure.
New setup will be biggest electric Weldon out of main tank to surge and a Weldon mech pump to the rail, woo.
I've got the weldon 2025 as my main and the walbro E85 as my lift, I hate the Weldon, it is the loudest farkin thing I have ever heard :(, the pump is rubber mounted the bracket that holds the pump is rubber mounted the plate that the bracket is mounted to is rubber mounted and there is a price of -12 Kevlar braided between the pump and surge tank, am going to custom a 10ltr with twin walbro E85 intanks, cause street car > race car
  • 2 months later...
I know its been a long time but progress is coming along my engine is finished at rips in nz i also have purchased a full fuel setup from rips aswell to fit in the rig
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
