Type 6 boards are out for R33 ECUs, far better than using a modified Z32 ECU
http://forum.nistune.com/viewtopic.php?f=9&t=2708
Nistunes are NOT rubbish, I've tuned 3x S15s with them and I have no issue with them. The software is decent too, and has the ability to overlay AFR vs. load points on the trace windows (which I find very handy).
Currently using Adaptronic too, decent ECU however the software is not as refined as others but once you get your head around it it's ok.
  • Like 1
Are the type6 boards actually available? There was a bit of fanfare but I haven't seen anything since.
What's wrong with nistune z32 modded ecu's for r33's?
Correct me if i'm wrong, but I think you only get partial knock detection, and an issue with the TPS which results in hesitation/poor driveability. Some people experience it, some don't.
I've got a Nistune in mine, and for the price, can't really complain. Had an issue recently where one of the tracks on the circuit board (not sure if Nistune or Mainboard) burnt through, and needed to be sent back for diagnostic and repair. Only cost like $80 for the fix including postage.
My main gripe is poor driveability on tip-in and closed throttle. Can drive around it, but means I need to ride the clutch a lot at low speeds. But, I'm told this is tune related rather than Nistune. Going for turbo upgrade soon so will see if re-tune fixes it. Also asked if ECU upgrade would be worth it and was told that Nistune would be fine.
In conclusion I guess, I'm not complaining with Nistune for the money. But if I were to start again, I would strongly consider getting something like the Adaptronic straight up.
  • Like 1
Yeah after the feedback from you guys and doing some reseach about it, I think i might just save up a few pennys and buy a Power FC.
Thanks again everyone!
  • 3 months later...
Just an update for what it's worth. After retune driveability issues are all gone. Cold start is great, and the issue I was having at part throttle has been tuned out. No limitations on Nistune there.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
