hey guys got a timing issue after a bit of help constructive criticism welcome
So recently just did water pump so I did a new timing belt at the same time as well as spark plugs
Got the timing light on I and its 30 degrees advanced but before that I drove it up the street and it spools like crazy and goes nowhere, obviously it's running retarded as hell, cas at full retarded gives me 25 degrees advanced so something is clearly wrong
By the way I've done timing belts before......
So took it all off to re check, and re did the belt incase i missed something,
All lines up properly on the crank pulley, and intake and exhaust cam marks all line up
Started it up again , sent photos of the timing belt marks to a mechanic who said all good
Sounds like a wrx and timing light says like 50 degrees advanced
......anyone got any ideas?
Also pulled the plug out and realised I got supplied rb25 plugs not rb20 so ill get rb20 sparkles in ASAP.
Got a spare cas ill try,
Obviously when cars under load the ecu is reading it knocking so its retarded the timing to keep it safe so I've got no power
But I should be able to get base timing right..?
Gonna check ecu codes ASAP too
Any ideas are appreciated
https://www.sau.com.au/forums/topic/441315-timing-issue/
The loop socks for some reason.
To use coil pack just plug a lead onto it to the plug (from a different car) and click pickup onto it
Have heard guys just open pickup and put it on the top of coil pack.
When the tps is disconnected it goes to base idle, otherwise the ecu adjusts timing to maintain steady idle.
https://www.sau.com.au/forums/topic/441315-timing-issue/#findComment-7245144
Disconnect the coil pack from the spark plug. Use a spark plug lead from another car to connect it to the plug.
Connect timing light to the lead.
A regular lead off a car with a distributor or an ls v8 will work.
https://www.sau.com.au/forums/topic/441315-timing-issue/#findComment-7245168
O.K to elaborate on the above, Plug the lead on the spark plug as you normally would with a plug lead. Now in the other end that would normally go on the coil/dizzy, put an appropriate size bolt in the coilpack and plug the lead into this (I put the head of the bolt in the coilpack)
Now I think you have to unplug the TPS or AAC to get it to sit on base idle so the timing remains constant. I cant remember this part yet but a google search should be able to find the answer (or search on here)
https://www.sau.com.au/forums/topic/441315-timing-issue/#findComment-7245211
Matt, if the key is broken, the CAS can go back in any position, but there is only one position where the engine will even start.
Idle is basically controlled with fuel. Variations in timing at idle are likely caused by the map being moved to a different load/rpm cell. Timing doesn't vary by more than 1 degree at idle, in my experience.
Callan, WTF? You don't need bolts shoved up coil packs. You peel back the small rubber cap on the "dizzy" end of the plug lead (maybe even cut it off) and the lead becomes the spark plug for the coil. The other end of the lead slips onto the spark plug (as it would in a "dizzied" application). Then connect the timing light to the spark plug lead (note the pickup is directional).
https://www.sau.com.au/forums/topic/441315-timing-issue/#findComment-7245458
Not entirely true, I have seen cars with the CAS out by 1 tooth or so and they still start (obviously don't run well but still idled fine)
Also I have seen (My car) range between 0 and 15 degrees timing at idle. Caused when the base idle is set way too high and the ecu pulls timing to bring it down.
  • Like 1
https://www.sau.com.au/forums/topic/441315-timing-issue/#findComment-7245491
Its how I've always done it. 8mm bolt, head fits perfect in the boot and lead fits perfectly over the shank of the bolt.
Nothing has been wrecked and it always works. I don't see what the big issue is
obviously you dont use a 20mm bolt to do this, I'm sure I'm not the only one who uses a small bolt, after all I had to get the idea from somewhere
https://www.sau.com.au/forums/topic/441315-timing-issue/#findComment-7245508
My car (s2 stagea) definitely alters timing to maintain idle.
When tps is disconnected it runs 15.
Yeah my engine manual says you need to disconnect the 'throttle sensor connection' so need to unplug the TPS
I think I had the timing jumping around within a few degrees of 15 when I did this for the first time with either my stock ECU or Power FC. Didnt have the TPS unplugged
OP you can either put the idle down to 650rpm (Which I think is too low) or try it with the TPS unplugged at 750rpm. I dont recall ever having to many issues. AFAIK Disconnecting the TPS tricks the computer into thinking it shouldnt be in the idle map so it goes to default map. It's harder without a scan tool or something plugged into the car to confirm it is at the timing you want. But if you check the timing with a plug lead and timing light, with the TPS disconnected and its pretty steady, I'd say you will be fine.
Try it with the TPS plugged in as well for comparison if you want. FYI I think you have to unplug or plug in the TPS before starting the car. So need to turn off the car, unplug, start car, check timing. Not 100% sure but think there was something like that
Edited by 89CAL
https://www.sau.com.au/forums/topic/441315-timing-issue/#findComment-7245519
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
