It is most likely hoses on the wrong way after rebuild, go back and recheck your work
Has it worked at all in its current state, if so it could be a faulty solenoid, if not then check the hoses are right
To check actuators you have to apply air pressure at different levels and measure how far the arm has moved on both to make sure they have moved the same difference, manual bleed valve will not fix this, this will most likely not limit you to 16psi either
You will also need to check preload on the actuators, done the same way as above, but this time record the movement vs pressure appied, IIRC they should start to open about 2psi under what they should set at and be fully open about 7psi over, this is because they don't have the manifold pressure pushing the gate open internally, I could be a bit off with these as I haven't done it in a long time, and this is most likely the problem
Not enough air flow would result in over boosting as it doesn't have enough air to open the gates and shut gates means no bypass which gives to much boost
What happens if you turn off the boost controller
Not my work! It is connected now, just working on 16lb, not what I want it to be which is 20+.
Is there a way to diagnose a faulty solenoid. Can I force a signal into it and check it for, I dunno, clacking noises.
Switching it out for a known working one is the best/easiest way if you can get one
What does it make with the controller off, or if you put a joiner where the solenoid is
Has this boost controller worked prior to this or is it a new fit and never worked right
1. I dont have one and live handy to approximately no one (Country WA). Other wise a simple replace piece by piece would be the go.
2. NFI.
3. Well it is a bit of a saga. Used to work but only at 16lb because that is what I previously wanted to run. Wanted to screw the thing up now but now it turns out it wont build boost. If it is fkd then for exactly how long it has been like that is anyones guess. The thinking was it was the stock actuators that were the problem. Replacing them was supposed to fix any boost spike issues but clearly hasnt.
As I said the easiest and quickest way to problem solve this is to get a manual bc, pre set boost with a compressor ,plug it in and see if your car boosts to that level. If it does send the ebc away to get fixed. Just make sure knock and boost cut management can protects things in case. 1 hour job.
How exactly do you set a manual bleed valve with a compressor ?
And if you can do it that way how does it allow for the pressure in the manifold trying to push open the wastegate flap ?
With the controller turned off it should run up to wastegate pressure, what happens when you do that, or is that when you get 16psi ?
My guess is still the hoses have been done the wrong way, get the operators manual and double check their on the right way
it was a joke in response to this:
This may be the problem do you think?..and seeing it holds 22psi without the bc.
If you want more power, you need more boost. If you want more boost, then its time to start playing around with your EBC. Or get a different tuner that can actually diagnose these things.
If you run 22 psi on actuator pressure, then your problem is your EBC, thats it.
I couldn't get more than 15 psi out of my GT3076R
problem was stock actuator (genuine Garrett)
replaced it with a 18 psi large can actuator from ATP Turbo
can get 26 out of it now
Has HKS actuators. I was told I needed to replace the stockers which I did. Still no more boost.
How much preload? Trent used to recommend 10mm as a starting point. Did you check they're operating in unison?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
