I understand the ratios in the GTS4 are shorter and suitable for putting in a GTR. However my question is what is the best way do do this. Scrounge around for a wrecked 4 (Of which I cant imagine there are many), buy new crown wheel and pinion or is there an aftermarket option or different donor vehicle?
The rear GTR diff I have has a Nismo LSD in it so obviously I want that to transfer accross.
Ah ok. Was a bit doubtful about the wisdom of finding a 20 year old diff and then trying to track it. Guessing it is drug money for a new version from Nissan?
By the way did it give you a good gain? I am sick of getting hosed by Emos out of tight hairpins etc on hillclimbs and the like.
Yeah I didn't look into the new price from Nissan; after all you are only reusing 2 gear wheels not the centres.
As for the gains; I did the change years ago so I can't really confirm back to back any more...I do know that I can hose those pesky Emos and WRXs off the line these days (it launches like a champ). More importantly in my case, because I have to run nasty 80's bush bearing turbos, lower gearing definitely helps get them come on earlier. The only place where I came close to having an issue was Phillip Island, and even there I was only doing about 6000 in 5th on the straight.
GTR gearing is pretty tall. So you tend to find that on tight hillclimbs and supersprint courses, even certain corners on certain circuits) there are times where you are stuck between gears (eg 2nd too tall and first is too much fapping about) or the thing is off boost (say exiting a 3rd gear chicane). Shortening it up can help mean it gets on boost quicker or it is less compromised when you have to pluck a taller gear anyway. If I could be stuffed I would do a engine torque cascade graph where you multiply the torque by the gear & diff ratio and plot it againt road speed. It tells you how much powahs the car delivers.
yep, essentially. 10% shorter gears are effectively 10% more torque at any given speed, with a trade off against top speed (which has never been an issue for me on any track I've been to).
particularly useful for me because I have to run nasty, laggy r32 n1 turbos.
Hey mate I'll try and get back to you tonight; and re cages the guy I would have recommended is no longer in business....they were good and cheap but too late now.
Any decent welder can do a decent cage like my car has, if you want something a bit special they generally get very expensive. Probably easiest way is to get a pre bent hoop from Bond cages and get someone to do the rest custom
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
