couple of questions...i'm sitting here going through some logging i did the other night in my car...here is the scenario and i'm wondering what is the best option...being first time road tuning.
on wot i'm running 11.4 afr's in p15 n17 with a knock reading of 18.
my question i'm pondering is ....should i pull fuel or add a degree of timing? timing in this cell is 18degrees @6100rpm
my mods are in my signature
any advice would be great
thanks.
https://www.sau.com.au/forums/topic/441761-map-tweaking-questions/
no problem just trying to get maximum efficiency. can you not get detonation with too much fuel? conversly with too much ignition? seeing as this is at the high end of the rpm scale i tought perhap a degree more timing might help.....this is where my thinking was going on both.....might have to do what gtsboy suggests :)
Im a bit confused as to why your timing is going up in the bottom right cells. It climbs from left to right be a degree every few cells. It should be the opposite.
as rpm increases the time between spark is reduced...which is why i advance the ignition as the rpm climbs.
Isn't that what IGN Dwell vs RPM is for
I dunno, now that I can look at my old map it seems I had more timing up top anyway. It starts dropping but did start higher. I havent done any tuning for quite a while now
IGN dwell versus RPM is for charge time, to make sure the coil is charged before the spark event happens. As a real rough rule the timing will typically be at it's lowest at low rpm and equal/highest at the highest rpm - the flame has to chase the piston, funnily enough at 7500rpm the piston will pull away from the start of the flame 3x faster than at 2500rpm.... if you used the same ignition advance the flame would be left for dead and just generate heat for no useful reason.
I wouldn't trust the pfc knock reading.
Only true way to get the maximum efficiency for that cell.
Is to load it up on a dyno and hold it at the poad point and play around with timing and fuelling
i agree, its not accurate but its all i've got at the moment. i'm saving for a knocklink.
whats the optimal AFR up the end of the map? is 12-12.5 still optimal?
how much boost are you running? and I suggest you run less and less timing as load increases (incase your actuator hose comes off OR you get a massive boost spike).
12-12.5 is consider ok up top, however most prefer to keep it under 12.
I usually like peak torque (roughly after max boost) around 11.5 then it tapers up to 11.8 all the way to redline.
"Optimal" is whatever the engine is happy with. It takes a dyno and knock ears to decide what that is. Some engines might like a little more fuel to keep knock under control, some might like a little less timing. It really so very much comes down to the specific combo of engine (age, condition, components, settings), turbo (compressor efficiency range it's operating in, back pressure on the turbine side) fuel and a bajillion other things that you can't tell if it's really happy unless you can watch its reactions to different settings.
For example, with a certain "tune" at a given load point the engine might be pinging a little bit. The dyno operator can choose to either richen up a tad or reduce timing. But which one he chooses will depend on whether the torque suffers more on one change than the other, or if the exhaust temp starts to become a bit wild and so on.
base timing is set to 15 degrees. thats a lot less timing than is used to have...stock they are up around 20 at wot.
i hear what you are saying gtsboy.....the knock ears will be a great help..... i think all cars need a happy meter.
stock is 22, however nissan never factored in 1.3bar into the motor.. the powerFC map is just to get the car going remember that
Did you set up the base timing while looking at what the power FC was doing? I can see the first 4 cells are 15 but mine used to get close to or overlap cells further then that. I used to do base timing with a second person. One person looking at the hand controller timing and the other setting it with a timing gun. I think unplugging the TPS cancels the idle map timing so it wont jump around as much
You've probably done it fine but just asking
best to pop it on a dyno, with those timing figures on a slow ramp you will find it will knock quite abit around 3600~4000rpm (assuming that's your peak torque).
I like to ramp the cars I put on dynos around 9km/k per second.. i.e. the car increase 9km/h each second... the shorter the ramp, the less stress and usually shoots up higher numbers.
I prefer to really load up the motor and let manifold glow.. think about a track, especially the straight at wakefield it's not a 400 metre straight it's quite long, thus more load on the motor
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
