umm just curious but why would it being a stock turbo make a difference? unless he's running smic? i would've thought timing and fuel would be his main issue here.
That was in reply to John asking about when full boost hits. As it's a stock turbo it would be on full boost quite early, and there is a lot of timing in that area. (And pretty much everywhere)
  • Like 1
you clowns obviously do not know how the ve on these things work, that tune looks kinda okay in the fuel maps and timing maps, if you look at a stock r33 bin image it actualy runs MORE timing up top!
ffs. ve on these things reference to another 2 places in the ecu to decide on the fueling.
now i am starting to understand why tuners lock their maps.
you could tune that ecu with most values in that fuel map at 50.
this ecu does not use a maf, its map based.
it calculates the ve a number of ways, rpm, map, ect, iat, etc etc etc.
they are a really good ecu, ve is better on the autronic and adaptronic though.
good kiwi company. what are the haltech's like? am looking at one for my mates pulsar GTIR.
a lot nicer IMHO, however you pay an arm and a leg for it. The software is more user friendly and the windows fit things nicely on a standard 1366 x 768 laptop screen
ive tuned many haltech's and link's / vipec... and i rate the belovid Kiwi's link and vipec over the haltech on any application every day of the week.
the link is better, the software is great... everything is on one drop down menu on the left side.... and the software is very customisable to show what you like while tuning.
the haltech is great also, would prefer it over many other ecu's on the market. but i really rate Link / Vipec.
So the fuel map after 60kpa is not to blame? Running 12psi boost.
^ do you have a wideband installed on your vehicle? I suggest you do that (when you get a new motor).
It's the timing map you should be worried about, not so much the fuel map.. Yes AFR is an attribute to kapowing motors, but in this instance your timing map stands out.
I won't say much about your map in public, PM if you want me to explain.
the haltech is about $400 cheaper than the link here. but based on what you say sounds like the difference might be worth it.
are you comparing the same ecu ? plugin for plug in ? extreme vs ps2000???
that timing map is not the reason why this engine went bang. it is not an ideal map, but it aint going to hurt anything. it could have been tuned a bit harder.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
