It's for a Ford 5 bolt housing.
Therefore I name it Harrihousing Ford.
Hit the Hyperboost Chewy! *MmmerreggggHHhGhhh*
Edited by GTScotT
  • Like 3
Most likely to to cater for the lesser used 6 bolt version of the same housing.
It is DEFINITELY the wastegate piece for a 5 bolt housing.
OP You should PM HyperGear about this and see if it even needs a gasket. He uses 5 bolt housings for many of his turbos and I do not recall seeing a gasket on any of them.
