Nice R32 and a great build what boost are you runing at the moment.
Running 13 psi. It drops back to about 10 at high revs, I guess this cause of the stock turbo, you do notice it a bit and really have to shift earlier to get solid power.
Just a quick update.
The R32 has been packed away in my garage for the next few months as I will be away in Norway with my Fiancee visiting her family.
Oh an I will be going to a little festival known as Gatebil.....
Full writeup coming soon.
  • 1 month later...
Well I am back home now after 2 months of chilling and going broke in Norway so I can continue with the updates.
The day I arrived home I could not believe it but the car started first go!! I had disconnected the battery and luckily it is brand new. I took it for a drive and all seemed to be ok.
The next day however.....
The water line that runs next to the exhaust manifold and around the back of the block had hardened and totally split dumping all the coolant on my garage floor.
Thankfully I had the day off and I got some water hose and fixed it. Was lucky I had the day off cause the next day was another Slidewize Skidpan day up at Gympie.
Car was amazing this day and I put it all down to running the 17" rims and new tyres, It totally changed the car, so much grip and much more controllable at the limit. I never will run worn down tyres for driving events again, they were the reason the car was understeering so much last time.
Not sure if it was going to so many drifting events while in Norway but if feels like I am getting better and can pretty much link all the different tracks they had setup on the day... MAybe time to try it on dry tarmac?
Car is in getting painted right now :)
Following is going down:
OEM rear bumper getting put on with GTR Pods. (Old fibreglass bar was filled with bog and cracks)
Front bar getting resprayed
Roof Spoiler
Took the old bar off and noticed that whoever put that vertex bar on has angle grinded off the rear tow hooks to make it fit... This sucks because I think they are one of the defining looks of the R32, makes it look more race car!!
So I found a wrecked one and cut them off and getting them welded on.
Hopefully get it back this week.
Also chasing GTR front guards and bonnet if anyone knows of some up for sale...
And in super fun happy amazing exciting news......
I ordered this from Japan!
Nismo GT LSD PRO!!
Without a doubt the most expensive thing I have bought yet but from speaking to plenty of guys and considering this car is street driven and I just do wet skid pan days I have been told this is the best upgrade for the money.
I am sure the old one is worn too and lost any of its "limited slip function" 200,000 kms and and more than factory power will probably do that.
So pumped to get it in the car!!
Can anyone recommend a good diff oil to use with it?
  • 5 weeks later...
Sneaky shot of how it is looking now... Could not be happier.
Paint is all done and factory rear bar is on. Also just picked up R32 GTR Bonnet and grill.
Plans this weekend include:
Steering rack bushes
Rear Sway bar and bushes
New Nismo gearknob... (Has an alloy one now and in the Queensland summer it literally scalds your hands when parked outside)
More pictures coming very soon... ;)
Could not help myself, here is a few more.
Will try to get better ones over the weekend.
Decision was made to put on the plates I have owned since I was 23. Actually used to be on my old 180sx back in 2004... funny how fads come and go...
Spent the last weekend under the car replacing the rear swaybar and steering rack bushes.
Rear swaybar is a Whiteline 24mm. Not super hard to put on, hardest thing was removing the old one, there was not room for it to come out because of the exhaust.
No noticeable difference yet, it does feel a little more solid in the rear end but until its driven hard its difficult to tell.
I also adjusted it to the softest setting, so might play around with the 2 settings.
Size comparison between the stock R32 swaybar and Whiteline 24mm.
Upgraded steering rack bushed to Superpro ones.
These where a bitch to fit, actually it was just the drivers side one. There is just no room for it to go in and it can only be mounted one way. I got it in multiple times but it was upside down.
Just used a ton of silicon spray and tied a rope around the steering rack to the strut brace to lift the rack up a bit so I could use 2 hands.
Noticed a big difference with these. Steering is much more direct and responsive. It also feels much more solid.
Old Bushings
Nismo LSD is going in today... little nervous as to how its going to drive. I really want it to retain some streetability.
You can adjust its torque settings so I am going to leave it to Medium and have it set to 1.5 way.
From all the research I have done these are very street friendly and not a whole lot of noise at low speed turns and regular driving but that remains to be seen.
I also went for Fuchs Titan Sintopoid 75W-140 gear oil..
Of all the online research I did this oil was not mentioned once. Everyone seems to say Redline but it was just too expensive and I could not get it in time. The guy at Bursons said this is lightweight and shockproof and the exact same as the Redline stuff. Also said that plenty of race teams are running it now. In fact he only had one bottle left and had to run next door to some Rally workshop to get another for me.
Description online:
Premium gear oil for axle and transfer gearboxes, formulated with fully-synthetic base oils. Offers best cold start behaviour. Suitable for axle and transfer gearboxes with and without limited slip differential. SINTOPOID LS 75W-90 is suitable as trouble shooter for conventional manual transmissions.
Really hope it all works out as I am going to the all Skyline Skidpan day at Gympie this weekend so I am totally out of time if something goes wrong.
Car is looking good man, where abouts did you buy the diff from if you don't mind me asking and how long did it take to arrive?
Bought it from Nengun Online. It was damn expensive... about $1200 plus the customs fees. I was looking forever on Yahoo Japan and locally but none showed up, or if they did they were thrashed.
Of all the guys I have spoken too who drift and race cars they say the best thing you can do is get a proper LSD, and because I wanted to retain drivability and legality I went for this.
Only took about 5 weeks, they told me it was going to be late November but a few days ago I got an email saying it had been shipped from Japan.
Nice thread mate. Looks like a clean car and you are only improving on that :)
I have the Nismo 1.5way and I have to admit it was probably the best mod I did to the car, following by bigger swaybars front and rear.
I also saw you Gatebil thread when you first posted it, super jealous!!! Lol.
Diff is in all but all did not go plan...
So got the diff in yesterday and I admit it "was" awesome. Felt super soild and more aggressive than standard. felt like it tightened everything up in the rear end.
Was a small amount inside wheel spin on tight corners but totally manageable and very easy to live with.
Went to the Skyline Skidpan day in Gympie and it was awesome, very responsive and would kick the rear end out with ease and felt controllable and you did not need to put huge amounts of steering input in to keep it sideways.
And then badness happened...
It felt like it happened instantly but I just got very loud bangs and knock when going around corners. At first I thought it was a cone but nothing was under the car. I got off the track and just did some tight corners and it sounds like the rear wheels are going to fall off, just loud bangs and knocks and very violent.
When driving in a straight line it is fine though, no noises at all. Only around corners.
My mate thinks its the oil, it has broken down and not doing its job. Im unsure...
Anyone have any input on this? I might try to change the oil tomorrow and see if it makes a difference.
Thanks mate!! Yeah already planning Gatebil 2015, I cant wait!! I recommend it to anyone who loves fast cars.
May I ask what oil you are running in your diff? How is yours on the street?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
