more the better,im driving 1.5 hours to represent the mighty 32s,cant have all the club turning up in 33s now.if you want to invite the vr4s go for it,just means more cars to chop,chop,chop,do you see the trend starting,lol
  • Like 1
the evo guys are a good bunch who enjoy theirs cars as much as i enjoy mine,and they drive sensibility on the most part,and dont mind having a chat afterwards.Am looking forward to catching up with you guys,but if you see me coming,just move over,lol.
  • Like 1
As part of the admin team of Qld Evo Owners I would really like to thank SAU for the invites to events like this. We really appreciate it & always have a great time with SAU.
Carl
Who would put you on the Admin team? Lol jokes. Hangover permitting, I may be there.
  • Like 1
Why you gotta be like that? :(
Depends how hard you crash I guess... Colin would probably disagree with you
hopefully no one crashes mate or tears hole in their block - unless it's an LS1
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
