  • Replies 42
UPDATED PRICE LIST
$150 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
$180 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
$10 Alloy BOV Bung/Plug
$10 110L/h Fuel Pump that fits in stock position
SOLD 2x Falken Azensis RT615 225/35/17 with around 3mm tread
$40 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo
$40 BRAND NEW OEM Rear Main Seal & Spigot Bush for RB2xDExx motors - 12279-5L310
$200 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece
$20 RB25DET S2 Factory dump pipe & down pipe
$20 RB25DET/RB20DET Factory Manifold
SOLD $40 RB25DET S2 AFM
$20 RB25DET S2 Stock Blow Off Valve
$10 RB25DET S2 Radiator
$10 RB25DET S2 Fan Clutch
$50 RB25DET S2 Stock SMIC & Pipes
SOLD $200 RB25DET S2 ABS Diff - minus ABS sensor
SOLD $20 RB25DET S2 Stock Anti Roll bars / Sway Bars (back)
$20 RB25DET S2 Stock Anti Roll bars / Sway Bars (front)
$10 RB25DET S2 Rubber Intake Pipe
$10 RB25DET S2 handbrake boot & gear boot (1x OEM 1x Aftermarket)
$10 RB25DET S2 HICAS Rack & Tie Rods
$10 SR20DET S15 Radiator
Keep seeing your npc clutch plate for sale, wondering if ill save much getting the plate from you and the rest jew from npc, as ive been wanting to get the npc carbotic 10" clutch to replace my slipping one...
Call up NPC and speak to Doug, OR alternatively, call Scott at Western Clutch at St Mary's and ask if he can sort you out. He uses the same pressure plates as Doug uses in his NPC clutch kits but sets the clamp only at ~1700kgs so the car is more driveable where as Doug goes for the moon.
Scott tested mine and it was over 1900kg of clamping force making the car a bucket of shit to drive and he reconfigured it to around 1700kg.. the car drives like a Yaris now after he curved my new clutch disc.
Il take the rubber intake pipe.. pm me payment details and postage costs.
Cheers
You sure you want it? Postage would be as much as the item lol
UPDATED PRICE LIST
$200 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece & no snapped studs
SOLD $180 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
UPDATED PRICE LIST
$20 RB25DET S2 Stock Anti Roll bar / Sway Bar (front)
SOLD $150 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
SOLD $180 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece & no snapped studs
  • 3 weeks later...
SOLD $150 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
Yezz.. sold clutch & rear main seal :)
SOLD $40 BRAND NEW OEM Rear Main Seal & Spigot Bush for RB2xDExx motors - 12279-5L310
$10 RB25DET S2 Factory dump pipe & down pipe
$10 RB25DET/RB20DET Factory Manifold
$10 RB25DET S2 Stock Blow Off Valve
$40 posted on the oil feed line?
Waiting on one dude to pick it up, if he falls through its yours for 45$ posted :)
$40 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo ~ PENDING
Will take everything here for a 6 pack of beer:
SOLD $10 RB25DET S2 Rubber Intake Pipe
SOLD $10 110L/h Fuel Pump that fits in stock position
SOLD $10 RB25DET S2 Factory dump pipe & down pipe
SOLD $10 RB25DET/RB20DET Factory Manifold
SOLD $10 RB25DET S2 Stock Blow Off Valve
SOLD $10 RB25DET S2 Radiator
SOLD $50 RB25DET S2 Stock SMIC & Pipes
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
