Hey guys i have installed a plazmaman intake onto my R33 Rb25det and it make a noise. thought it was leaking so i used 3 type of gaskets, Stock rubber, Plazmaman gasket and the cosmetic one but its still the same :(
When i put my hand on the intake plenum the noise goes away.
here is a video of what i mean any one who has a plazmaman intake on their Rb25det can you please help me out, or is it meant to be like that.
https://www.youtube.com/watch?v=6vq77Wi3MTI
https://www.sau.com.au/forums/topic/442530-plazmaman-intake-problem/
Vid didnt work for me...
If you think you have a leak do something to check if you have a leak!
Either pressure test or as it would be a vacuum leak spray some carb cleaner or similar and listen for rev change.
  • Like 1
sounds like an air leak to me... i dont remember mine sucking so loud. i could be wrong.
the gasket between the bottom and top of the intake manifold is a bitch sometimes, the rubber gaskets dont work too well on the plazmamans... try a pressure test just to be sure.
