Cam Duration And Vacuum Lose Rb26
Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
FYI: Racebox RE7R Custom Tunes Released! https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm... FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
