Nice PM's guys.
May I suggest that the first mod should be a transmission cooler?
Leave the fun stuff until later, they need a trans cooler over here.
Doesn't it get as hot in japan as it does here? Also, I'm ganna make a guess and say they have far longer traffic jams?
I haven't put a trans cooler on my car yet and it hasn't gone into limp mode. Not saying he shouldn't, but I think if he's not going to modify it or tow, it should be fine right?
If it absolutely needed anything wouldn't it be better having scotts bypass mod or VB upgrade?
Looks like my first mod will be the Transgo Shift Kit, through Jetwreck.
How does the transmission cooler benefit?
And what's Scott's bypass mod & VB Upgrade?
VB upgrade is the Transgo shift kit.
Scotty's bypass mod is a cooling system add-on; this allows the cooling system to be purged of air extremely easily (this is one of the most annoying jobs on the whole car, and is critical to the safe running of the engine). It also cooling water to circulate from a dead area in the back of the block, back to the radiator. This allows temperatures to stabilise very quickly after a high load event.
This mod is literally worth it's weight in gold. :wub:
  • Like 2
The coolant bypass kit is not very heavy mate, it's worth more than that. :P
Thanks Dale, glad you like it.
  • Like 1
No, Japan's summers are not as hot as here and their cooler months are definitely colder than ours.
Decent trans coolers (hell, even small horseshoe shaped "coolers") have been found to extend the life of markedly and IMO should be on every car - feel free to ask EF Falcon/Futura owners who have their transmissions sealed from factory.
You are correct though and yes, I am a forgetful idiot. Scott's coolant bypass is without question the first thing I would install if I purchased another VQ (unless it has it from factory).
VB upgrade? Nah, not that high up on the list of things to add to a fresh PNM35 although I do appreciate the improvement it makes... hell, it is still behind roughly $3-4k of mods on my list.
Edited by iamhe77
We've already got a trans temp regulator type set up anyways... i guess, Also isn't a theory behind VB upgrade is that because there is less (slip or friction) so there is less heat generated between shifts?
Heh, not trying to come at you bro... I also forgot those mods in my #22 post in this thread :P.
Edited by M35woah
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
