Hi all..
Just wondering if I can use my neo pistons and rods in an r33 block with an r33 crank?? Not sure of series 1 or 2 if that helps..
My neo crankshaft has an overly flogged out keyway and my block has a crack from a water jacket to the head stud.. also has been decked twice so wouldn't bother repairing the crack and decking again..
Got the r33 bottem end free so want to make use of it if I can..
Any help would be greatly appreciated..
Cheers
https://www.sau.com.au/forums/topic/443075-neo-internals-in-33-block/
Wait, the 33 and 34 heads are different. The neos are smaller cc's right? So if you put 34 pistons on, the comp ratio would be really low on a 33 head right? But you have a neo head? You just want to know if the 33 block is the same as r34 yeah?
Most people reckon the blocks and cranks are the same but the rods are RB26 , so the pistons have to have larger diameter gudgeon pins and a lower crown to get the same CR with the smaller Neo chamber . IMO minimum changes to the R33 short are rods and pistons to run the Neo head .
Sorry, but I am going to be 'that guy' here.
So if I was to forge my neo, so I can run more boost, would I need to change the crank and rods? Obviously pistons are a must, but if I balance the crank, and the rods (if they are 26) should be pretty strong ay?
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
