This has probably been covered before, but I thought I would start a new thread for some fun especially with the popularity of E85 these days.
So, post up times of completely unopened OEM RB26 GTR's 1/4 mile times:
A quick search gives me:
XRATED: - [email protected] (R32, 396rwkw)
Tynago: - 10.7@137 (R33)
DVS Jez: - [email protected] (R32, 402rwkw)
GO!
Sorry to get off topic here a little. Isn't that gtr still running a H box. Does anyone know.??? I've seen the attachment that makes it shift that way but I just can't remember the name. Help.
No, [NITTO] runs an OS88 Sequential 6-speed.
You are referring to the Ikeya Formula Sequential Shifter that can be used with the OEM H-Pattern:
http://www.nengun.com/ikeya-formula/sequential-shifter
GO!
wow... that was a long time ago..... that was before 98 was even available at the pump in Tassie, little own E85! ha ha ha
... well hoping to run a little quicker next year with a new engine (and everything else).
Cheers
Justin
Yeh I did 11.30 @ 127mph stock engine stock head 98 octane with t517z turbos
XKLABA did 11 flat I think stock engine stock turbos
11.3@125 stock every thing in full weight R32
11.1@123 new HG and big ends bearings on drag radials with 293rwkw
Would still be interesting to see the results, Simon.
Thanks for the info guys.
I would think that with these engines getting older (25 years now), that it would be hard to beat those previous times (10.6's!)
My 33 has run 11.5@126mph weighing 1760kg with only -5's, ecu, fuel pump and injectors on E85. Bigger cooler and exhaust should help.
I might give it a crack while I get my built engine ready and see what happens :D
Last year on a unprepped runway (Racewars) I did a high 10 @ 136mph with approx 640hp at the hubs
Same runway this year I was doing similar times and trap speeds but with a passenger and a full tank on fuel with around 700hp at the hubs revving to 8000rpm
With a few more revs and less 150kgs of passenger and fuel I would hope I'd be around 140mph+
Might give it ago when the drags open back up over here but the gearbox may not like it :yes:
Edited by SimonR32
I've often thought about getting a good condition unopened 26 and slappin on all my 'big' bits and seing just how far it would go. Willall did it back in the day, but with a freshened up 'to stock specs' engine... so it doesn't really count.
It'd be cool to run 9's/140mph+ on an un opened engine in a true street GTR. We'd allways be at a disadvantage to stipped out auto GTR's though.
J.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
