1) Please feel free to list up your ECU brand and model!
2) Put up Qs (in detail) here too and Adam will try and answer them on the day
3) Or anonymously email Adam with your Q to [email protected] and again, Adam will answer it on the day
Many Thanks Adam :)
IN! Gem did my last tune of my AVCR boost control plus my hi flow turbo.
My ECU :STOCK!
Would love to know which is best for a street car which does some texi and drags, Id love to get rid of the AFM and also have Anti lag/boost control. And possibly a E85 tune along with a normal premium tune which can be selected depending on situation. :)
EDIT: me plus the Boss (Wife) ;) Will also bring go pro for video and happy snaps :)
My ECU :STOCK!
Haltech... or GTFO :ph34r:
Pleasure you guyz!
You may also notice that 4 Members have been upgraded to "(E)" - Exec Board members; as 4 will stand down.
Congratulations to DekA (Matt), zebra (Drew), Redline_GTR (Chris) and MR33YO (Jason).
Feel free to consult any of the Execs about processes within our great club.
Great!
Requested ECUs up for Adam to discuss are...
Apexi PFC, PFC D-Jetro, Nistune, HKS F-Con Pro-V, Adaptronic, Motec & Haltec
Any others?
holley 750 double pumper?
Lol
and thanks for the welcome to the exec club :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
