  • Replies 302
isnt stock boost on R33's like 7 pound or something???
to be on the afe side maybe turn it down to 9 or 10
it comes down to another case of jimbo's crazy turbo, boost cant be changed up or down for the moment.... soon after the trackday iplan to have this fixed up but unfortunately not before.
I will try and make this one.
Is there anyone out there that will be driving down on the day as I spent all my money on port in the hunter valley and cant afford accomadation
By the way Tosh, how much for accomadation?
If i can get the day off, i'll be driving down on monday morning! :D
OK Guys & Gals I have got prices from The Goulburn Heritage Lodge
Two Bedroom Family
Rates are for 4 people. Maximum occupancy is 5 people. Charges apply for extra guest. Bedding configuration is a queen size bed and two singles. Spectacular sized rooms. Facilities:
Air Conditioning
Bath (there you go Kelly :))
Cable TV (wOOt)
Dial-up Internet Access (if you need your SAU fix THAT badly :thumbsup:)
Fax/Modem Telephone Line (if your an uber geek with your own laptop :))
Hairdryer
In house movies
Ironing equipment (so Duncan can iron all of our clothes :P)
Kitchenette (basic facilities)
Opening Windows
Tea/coffee making (ohhh we're goign to need it in the morning)
$109 per room per night. Sleeping 4 people
$32.70 EACH
List of people staying:
Tosh
Duncan
Kel
Scott (TRW Member)
Chris (CRAVED)
Jeremy (Endorean)
Nathan
Pete (Fatz)
Tim (CS_180)
Andrew (Merli)
Ken (Akira)
if we get 1 more person to stay, we'll fill all 3 rooms we need and bring the price down to $27.25 each
if I've left anyone out please let me know.... also is everyone cool with that??? If not I can try and find another place
how long will the day last ??
cause the 26th is actually my first day back at uni.......but hmm...i got friends to get notes for me :cheers:
so ill prob make it......but just wanna know roughly what time we will finish ??
i can leave anytime in the morning....
just need to know an approx time i will get back to syd.....
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
