That's what I run. It's a good reliable turbo. You will need an external housing for it, I have been using the Taiwanese stainless ones with great success, also the Kando housings work very well. I picked mine up on sale at MTQ a few months ago for $930.
For an Rb30det the turbine housing is too small. You can get more power and hold boost better by just replacing the .63 turbine with a .82 turbine. It should get you about 300rwkws, but I don't think it will do more.
Alternatively I do have 10cm turbines that is made for external gating that I can machine up to suit the current core and you can get Scotty to drill and weld an gate on the side of it.
change the diff ratio first! before doing anything else, it will make a world of a difference
* (if you don't have the torque to push the higher gearing)
I listened to similar advice and wished i didn't. All I noticed was worse fuel economy due to 500 revs more on the freeway. If it's a road car you really need to think twice.
Diff has 4 pin borg warner conversion so its not an issue. 355 gers will make the car prpell faster but also makes wheel spin easier too. if I exturnal gate the op6 to control the boost in the top end and go e85 I think it will make the power close to what I want.
  • 3 months later...
Well I have picked up a gtx3071r. From what I have been informed this turbo won't be able to make the rwhp I want. Spoke with Mike vine turbos in Brisbane. They told me to get the power I want I need a minimum of a gtx3076r or better yet a gtx3582 with .63 rear. Thats on pump fuel. If I change to e85 would it make the power (gtx3071r) that is.
I make 330kw at all 4 through an unlocked stall converter, the GTX3071 will easily do it, on the stock manifold if you externally gate the housing. Even internally gated it will crack 300 on e85.
The GTX3076 is a 400kw turbo on ethanol.
If you plan to run petrol you may have a hard time making 300, but it could still get there if you have a great setup. I just don't like leaning on petrol tunes that hard...
Ok. I now have these mods to do. Custom hi mount manifold with exturnal gate. Gtx3071r turbo. 1000cc injector twin 044 pumps head has allready been ported stage 1 pon tom cams 3 inch turbo back exhaust 100 cell cat. 600x300x76 cooler and change to e85. Should get me to where I want to be. . Will I need head studs or anything else.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
