It worries me a little that you have honed bores and reused old pistons that's in essence increasing the piston to bore clearance which would also increase your ring gap. Problem is unless you measured the Bore with telescopic gauge and micrometer you couldn't be sure how much taper the bore has, I've made a few assumptions here but it's just from experience also where did u set your ring gaps at what point in the cylinder ? How far from top?
Scott
Time to take it for a blat as per the earlier advice given to create pressure to push the rings on to the bore and bed them in
good luck
Post back results
Agree, run it in hard.
My fresh engine did 30x >300kw power runs after I drove it from first start to the dyno ~15min away.
Give the rings a chance to bed in and see where you're at after some (loaded) driving.
Mark :)
Scott
Was about 20-30mm from the top of the cylinder
Scott
Not to completely disagree, but just chuck some more Info in the mix.
The larger bore will reduce the amount of force a ring will exert on the bore (by a tiny bit)
Which will make the ring gap bigger, but in the scheme of things a larger ring gap gap by itself really has a negligible impact on the engine
http://www.diagnosticengineers.org/journal_%20articles/Ring%20Gaps%20vs%20Knowledge%20Gaps.php
If he has fitted new rings then they really should have been gapped to the bore after honing it, and those honing tools take 2/5ths of F all anyway, this is how I did my 32 last time and it has held together for a few good hard years of abuse and ran some really good numbers given its set up
To give a consistent 100psi then I would say something is a miss machanically, most likely cam timing
Thanks for all the info guys been giving it some stick over the weekend boosting from second gear upto 7000rpm 3rd about 700rpm and then just a little in 4th upto about 200km/h then down to about 80km from 2nd again and again
now I havnt checked the compression as yet I will try get a diffrent gauge aswell and lets see what the outcome is will keep you posted
It's actually funny how the old and sensible instruction to avoid idling a newly built engine coupled with the old and sensible advice to run the engine through a variety of loads and speeds (but not high load or high speed) has translated through the last 20 years into thrash the living f**k out of it from cold startup.
You don't need to arse rape an engine to get the rings to bed in. You just need to drive it sensibly.
  • Like 1
True if numbers are even that should be an indicator of another issue , I would personally never just hone. A 26 as it's such a big job to get to that point but each to their own I guess really in worst case could be a bit more blow by or just a more noisy engine but as was states earlier honing doesn't take much off but my point was more that an engine that has run for some time may have a taper in the bore, on some of the lesser engines I've built eg Honda lol if just being honed only I would check
The ring gaps at 3 different spots in the bore to make sure I wasn't going to have any dramas . Hopefully it's just a gauge issue in this case as sometimes it's the simple things that cause the most drama . Best of luck to the op ,
Scott
Ok so tested compression again
And all seem to be the same 100psi when i put s9me oil in the chamber the increased to about 116psi
This was done with all 6 plugs out and the apexi read about 180 rpm should it not be 300rpm?
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
