The Brembos, the DBA and the RDA rotors are all from ching chong land, if you think the brembos are from Italy, your mistaken, we personally know the person with the Brembo contract for Australia and also know because we sell rotors and pads for a living.
My only advice is stay away from cross drilled rotors which are prone to crack.
Biggest effect on the rotor is the pads you chose.
If you use the option to show in AUD it converts to $1,103.88 each plus delivery. Compared to the price that Nissan Australia wanted for the same part that is cheap.
Tell you what - I have multiple sets of front disks for R33 Brembo callipers in my parts shed (spares for my GTR and my track car). Some are new RDA slotted rotors and some are factory Brembo rotors.
The Brembo ones have been machined and are in good condition. I would be prepared to let them go for $1,000 for a pair and I will cop the loss.
Hahahahaha
OP, get plain rotors from DBA or RDA, you won't notice the difference. Or DBA 4000 for some extra street cred. It'll cost a lot less than $1,000 per rotor.
  • 1 year later...
Hell, id better get some of those Genuine Brembo rotors in from my supplier and start selling them for $800 a pair new, im going to make a absolute killing on them. :)
If anyone here in Sydney is after used rotors in good nick with still a couple of mm on them you can have them gratis.
* They're off my BNR32 V-Spec II with Brembos
* They've been replaced with dba that came my way through good fortune
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
