felixy69 Posted June 13, 2014 Share Posted June 13, 2014 My motor rb30/26 + t78 turbo Wat difference will I see when using haltech platinum pro compare to power fc ? Thx Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/ Share on other sites More sharing options...
iruvyouskyrine Posted June 14, 2014 Share Posted June 14, 2014 A lot less money in your bank. What will the car be used for and what fuel are you using? Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7311358 Share on other sites More sharing options...
iruvyouskyrine Posted June 14, 2014 Share Posted June 14, 2014 A lot less money in your bank. What will the car be used for and what fuel are you using? Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7311368 Share on other sites More sharing options...
felixy69 Posted June 14, 2014 Author Share Posted June 14, 2014 street use mostly Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7311705 Share on other sites More sharing options...
Ben C34 Posted June 14, 2014 Share Posted June 14, 2014 Nistune. Flex fuel had been released for 32 gtr ecu. Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7311721 Share on other sites More sharing options...
XKLABA Posted June 14, 2014 Share Posted June 14, 2014 As much as a nistune can be fitted it is a mission into a R34, their is a thread all about doing it if you search for it ( OP, not Ben I know he knows all about it ) I would use the PFC for a street GTR that doesnt want Flex Fuel any day, the only problem with the PFC is as much as most every tuner can tune them, very few know how to do it properly/fully, I have a PFC in my R32 and have done so for 7 years and it drives better then it ever did with a stock computer, though it didn't when it was first fitted and tuned but then I found Scott and it has been brilliant ever since and given how fast my 32 is given its power output proves it My 34 had a PFC in it when I bought it and it drove quiet well then I let Scott at it and again became perfect to drive and if it supported Flex Fuel it would most likely still be in there This is my opinion, blast me all you like for it it won't change what I have seen for my self and how I feel about it, I like the PFCs and when tuned properly do exactly as they are asked with no fuss Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7311727 Share on other sites More sharing options...
GTRPSI Posted June 14, 2014 Share Posted June 14, 2014 Depends what you want to do, or how far you want to go. Does a normal power FC have launch control, antilag, ability to run on a MAP sensor, spark cut RPM limiter and the ability to simply add extra devices through expansion ports. (not talking Jetro or Pro series Power FC) None of which should be needed on a normal street tune GTR....but needed if your getting serious or you have $ tied into your engine. We went with the Haltech Platinum Pro because it opens a range of future possibilities, even something as simple as the race dash pays for its self, no need for expensive gauges and mounting, warning high low limits can be set on a wide variety of things your monitoring or worried about. Having said all that, Power FC covers what most people need day to day, good thing is they are getting cheap because newer ECU's which are in demand like the Haltech, i wouldn't hesitate to run a Power FC on a mildly worked daily driver. Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7311851 Share on other sites More sharing options...
XKLABA Posted June 14, 2014 Share Posted June 14, 2014 Better throw this in, I for some reason thought this was for a R34 GTR some disregard where I said about fitting it to a 34 Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7311870 Share on other sites More sharing options...
eXquiSit Posted July 15, 2014 Share Posted July 15, 2014 any updates regarding this? apart from the extras GTRPSI has mentioned, just simply for tuning how do they compare? Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7339750 Share on other sites More sharing options...
XRATED Posted July 16, 2014 Share Posted July 16, 2014 15+yo PFC or a brand new, current tech haltch that's been designed/built/developed in Aus and is very flexible? as for just the tuning? better resolution, more options to offset timing and fuel trim etc. Same same for any competent tuner to 'use' or 'tune'. The one thing that I would have liked in my PS2000 was knock correction, but the plug in (my pick for your application) does have knock correction. J. Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7340859 Share on other sites More sharing options...
Simon-S14 Posted July 31, 2014 Share Posted July 31, 2014 Link G4+ extreme all the way. shits all over everything mentioned in this thread Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7355611 Share on other sites More sharing options...
Nismo 3.2ish Posted September 11, 2014 Share Posted September 11, 2014 What makes the Link G4 so different from the rest?? Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7387024 Share on other sites More sharing options...
Nismo 3.2ish Posted September 11, 2014 Share Posted September 11, 2014 My motor rb30/26 + t78 turbo Wat difference will I see when using haltech platinum pro compare to power fc ? Thx Hope the RB30/26 setup you have with the T78 works better than my T78 worked for me on the street, it was a pig to drive as a DD and did nothing until 5000rpm Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7387160 Share on other sites More sharing options...
Simon-S14 Posted September 11, 2014 Share Posted September 11, 2014 a t78 isnt even that big... it was probably more to do with your tune then the size of the turbo Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7387203 Share on other sites More sharing options...
Nismo 3.2ish Posted September 11, 2014 Share Posted September 11, 2014 I had a worked Rb26 motor, forged pistons etc. From what was said to me, it is hard to get the T78 to come on full boost before 5000rpm, mine was later , at about 5500-6000 for full boost and rip your head off. Maybe it was the tune, I am new to this but everything I have read so far indicated that they get full boost no earlier than 5k with an RB26 motor. I put a PT6262 and poncams B and it was a different car tuned by the same bloke?? Maybe everyone has a different idea of lag, but mine was SO LAGGY and with the quad clutch a sh@t to drive, full load and steep hill take off, it was hell on wheels. I do not mean doing a 6-8000rpm launch, maybe the clutch had a lot to do with it??????? Sorry off topic Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7387242 Share on other sites More sharing options...
kaneryan Posted October 5, 2014 Share Posted October 5, 2014 i owned a PFC with -5s and now changed to a Haltech with a HKS T51r yes both different turbo setups but changing from the PFC to Haltech everything seems alot smoother with the Haltech!i do agree with the above every tuner pretty much knows how to tune Power FC but i also agree with XRATED they are designed, newer technology and you have everything there ready to go if you decide to change for a track setup or E85 or Flex tune. it also allows you to use alot of add ons as also mentions above. but to that is double the price of the PFC but, i found the PFC to feel very strange when it was cold, i cant quite describe the feelling but you can definatly notice the difference with the 2. as for a tuning perspective i dont know which one is "nicer" to tune, but thats for your tuner to work out. also choose a computer your tuner feels most comfortable to tune, Link to comment https://www.sau.com.au/forums/topic/444379-rb3026-power-fc-vs-haltech-platinum-pro/#findComment-7402578 Share on other sites More sharing options...
