Hi all,
Up for grabs is a set of 4x R34 GTR wheels which measure 18x9 +30 all round, and are currently wrapped in 245/40 Advan AD08 tyres.
These wheels are not like other GTR wheels I've had before, these are in the less common colour which I am lead to believe came out in the Nur spec 34 GTRs?
Anyway, it is the set to the left which are for sale. They have the usual gutter rash on each wheel as can be seen in the photo below.
10346975_866742840008145_1794348662_n_zp
10379199_866771296671966_907735784_n_zps
Wheels will come with their centre caps.
The wheels are located in the south east suburbs of Melbourne and I would rather a local sale at this stage unless you can arrange your own postage.
I am after $1500 for the set. I'd be keen for swaps, but they must be 18s and 9" wide minimum.
Contact is best made through PM or by posting here.
Thanks,
Adam
Edited by adam-__-
Hmm now that you've posted that up, mine are definitely not that colour! Mine are more of a champagne/bronze shade.. I will post up a better quality photo of them tomorrow (today)
Perhaps Nissan made 3 colours! > Which means that yours were Nur-dedicated after all!
The ones I posted up were for Midnight Purple.
But either of the light colours would certainly suit a car with a dark body-colour.
Here's another photo taken with a proper camera!
I guess we can't rule out the fact that it is resprayed in a custom colour altogether.
For any interested parties, the above wheel is an indicator of how the others wheels are also in terms of gutter rashes.
Hmm well there you go! I can't seem to find that article/thread where they mentioned it but it might have been just the illusion of the Nur coloured cars.
Either way, the wheels are a lighter shade and look great against my white car, compared to the usual grey.
Edited by adam-__-
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
