One In A Row
r32-25t
 Share
C'mon guys, I think the mexicans deserve some real credit here:
They've finally managed to just scrape through and get themselves a series win by the skin of their teeth, and it only took them 9 years of trying. Well done guys!
If they keep playing football of the same caliber and quality as they have shown the first two games this year they should easily be able to keep up their current standard and win a series or two every decade.
NSW would be considered Americans, QLD Canadians and Victoria Mexicans. Get it right
2013 was decided by a 2 point margin & 2012 by 1 point, skin of the teeth argument is invalid, this has been coming. Also take away all points scored for QLD by Inglis or Folou and you dont have a 8 year streak.
Game 1 was a cracker of a game that was marred by terrible reffing in the final 10 minutes. Game two was shit by both teams
  • Like 1
This describes my feelings in a way that my hung over mind can't articulate. Thank you kind Sir.
Why would we be taking away points scored by Folau and Inglis?
No they went to dream world once so that makes them Queenslanders.
Like last night they talked about ingles being pound of his heritage, I laughed and said so proud he is playing for the wrong team
  • Like 1
Inglis - first senior game at 16 for Newcastle Hunter in New South Wales and his first under 18s game for the Brisbane Wombats in 2004
I have no idea's about all the rules around which state a player must play for if they get to choose :wacko:
Also what about Fijians, Islanders and NZ ? Should they play Origin at all ?
I remember seeing a funny map of Qld that seem to take in the whole south pacific including Vic and parts of NSW.
His heritage is Indegenous
Off the top of my head Peter Sterling, Ben Elias, Bradley Clyde, Timanah Tahu, Willie Mason and Peter Wallace. All not from NSW all played many origins in winning series for NSW all because of the same eligibility criteria you all want to bitch about now.
But you will keep whinging about it one way, and ignoring it the other.
Was a good passionate game to watch, but refs took the edge of it. So many bad calls. So much niggle. Don't usually see qld do that. Usually a nsw tactic, spearheaded by Gallen.
I guess you play like them and end up losing by them.
So this is the best team qld have ever produced? And nsw beat them! I like the fact qld supporters focus on the last 8 years only and never before then, never back when qld and nsw played against each other since 1908. Never back when nsw beat qld 19 years in a row in the 60's, yes it wasn't called "state of origin" but it was qld verse nsw. Got give credit for the teams back then when it was brutal and not a penalty riden whinging comp from both sides like they play on the ref these days. And also Shayne Hayne should never ref a game of league ever again!
The qld supporters that give shit about nsw playin at their home ground badly and only just winning, game one was on your turf and u lost so says abit about how qld played on their home turf. At least we won!!
Can't wait for game 3 to make it a white wash guna be tough but will be good to see it happen!
Edited by smidy
  • Like 1
 Share
    • Updating results.  Using ATR45SS-0 model VS UHF57-900. Those two are very different turbos, different wheels sets with different wheel hub profiles but yet with almost identical result. I’m intrigued with both turbos performance. ATR45SS-0 was a 61mm turbo first developed in May 2020, UHF57-900 was a 62mm turbo developed in March 2024 as a powered up alternative of a G30-900. On paper ATR45SS-0 maxed at 563rwkws, while UHF57-900 maxed at 568rwkws. ATR45SS was slightly more responsive with slightly better power band through the mid range.  Road driving ability, ATR45SS-0 had better throttle response, felt more robust under throttle, as it wakes up earlier. I think G series wheel hub design made it to have higher inertia under light throttle. Doing bit more prototype work in the next few weeks, will update result when its back on dyno again. ATR45SS0 Blue, UHF57-900 Red Chequered tuner's Dynapack hub dyno, E85 fuel. Mod list is in video below video_20240604_114214.mp4
    • Did you run the power cables for the mac valve to the other side of the car near the fusebox? Utilizing the stock boost controller cables? or did you run new ones?
    • Hey I have a potentially stupid HICAS question 🤣 I'm currently doing a full hicas delete, Power steering pump modified to non hicas, all lines removed from the car along with all electronics. My stupid question is - Do I need a lock out bar? is there any reason why I cant just remove everything from the rear end? I already have a lock out bar but thinking to save a few extra grams I could also get rid of the arms and tie rods as well and just run it with nothing in its place? or would it have a negative effect on handling?
    • Hi how are you guys?  I know i have been absent for years but im coming back slowly guys just wondering if anyone know where the ball joint on the NISMO arm front and rear can be replaced with OE parts?  Also  i know this is not the thread looking for springs and blistein shocks for the 260rs. Please advcie     cheers    yudy
    • Hi i do you have for stages 260rs?
