Okay so im deciding what turbos to upgrade to and want to know everyones opinion.
Im wanting twin high mounts and want to get around 500kw or more..my motor is fully built and just needs a few extra goodies.
Im running greddy t517zs atm and its got over 300kw on low boost.
Im looking at getting a set of greddy t67-25gs as ive heard really good things but want everyones input so please feel free to voice your opinion guys.
Thanks
https://www.sau.com.au/forums/topic/444836-best-high-mount-turbos/
On petrol, or E85? What is "fully built"? Please elaborate on specs, and the rest of the setup etc? External gates? GTX2867Rs are the first thing that come to mind on the assumption you will be running E85.
^ As above..
Also need to understand what your car is used for and what you expect out of it in regards to drivability. As much as I love twins, for big power like 500kw I would lean towards a big single like a PTE6466 or EFR9180.
Whatever you do, stay away from the T67. That thing would be nearly 20-30 years old by now (technology wise)
Edited by Tonba
Sorry guys.. Motor has forged pistons, rods, big injectors, fuel rail, n1oil pump, nismo oil cooler, nismo intercooler.. Its on pump fuel ATM and plan to get cams, cam gears, e85 and a few other goodies.. I want 450-500kw and was thinking td06-20gs for it as i think running twin t67s will be too laggy as is purely for street use. If i run the td06-20gs.. I'm not sure as to run 8cm or 10cm??
Thanks
^ TBH, stay away from the Greddy / Trust turbos. They are laggy by todays standards.
Get yourself a pair of GTX2867R like Lithium suggested or a big single like a PTE6266, EFR8374, PTE6466 or even a EFR9180 (all in in twin scroll configuration for response)
Edited by Tonba
swings and roundabouts...
1. do you really want 500awkw? if so (unless it's going to be a hard parker with a dyno sheet in the windscreen)
2. start saving for a new gearbox
3. cash in the rego, throw in a seat, cage and buy a trailer (because unless your looking to get more cubes, it'll be essentially useless on the street)
4. start saving for all the supporting systems (I'll guarantee your fuel system wont support 500rwkw, clutch, cooler, oil and breathing mods, diff/susp/brakes, ign system, ecu/tune.... )
and the list goes on into a big spiraling dark hole of time/money and sacrifice/compromise
Cheers
J. :-)
You should get close with GTX28's shoved into -5 housings, twin Walbro 460L, possibly 1400cc ethanol/methanol injectors (or just put 2000's in there)
The rest can be done on a surprisingly stock engine bay, but be warned, the 26 block is very weak up around that power. I would be going for an unmolested 3L block and not boring it out much.
Nah, 26 block is no stronger or weaker than a 30 block, do what everyone does and do a partial grout fill for ridgitidy.
If anything the 26 block has oil squirters and the block grove for extra mains oiling already there, i wouldnt jump to a 30 block just for 500Kw.
Good Oil pump is a must in any RB build as is oil control mods.
You can get 400-450Kw with a set of low mount -5 and E85....
Edited by GTRPSI
Appreciate all your input guys..
I'm totally new to all this so i do appreciate all your feedback guys
To start with, be honest with yourself and really have a good think about what you want to get out of your gtr and how you would like to use it. Once you figure that out, you can start setting goals and planning mods/asking for advice for the best way to get the result your looking for.
Cheers
J.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
