Hi all.
First off, RB25/30, Hypergear SS2, 20psi, E85, 45mm external gate. Car will be driven on the street semi-regularly and will do as many drift days a year as possible (probably 6-7)
I had originally planned on getting an Adaptronic and converting to MAP sensor for this build, but cash is very limited at the moment so now i am asking you guys for your advice. I already have a NIStune and a Z32 AFM, so i am thinking i may stick with that setup. I do have some questions though;
> Would a Z32 max out at 400kw on a 3 litre bottom end?
> Is there any issues running the AFM in the cooler piping?
I don't think i really need any of the features the adaptronic offers, the only thing i am unsure about if the ability of the nistune to keep the engine safe in undesirable conditions as it doesn't have any spare inputs for oil temp/pressure etc. I guess i will just have to do it the old fashioned way and keep an eye on my guages! Just trying to figure out where my money is best spent, and i think the NIStune will do the job fine provided the Z32 AFM won't be a restriction.
Thanks guys
https://www.sau.com.au/forums/topic/445084-ecu-reccomendations/
Link g4+ do you wish to data log or input wideband?
The hot wire mass air flow sensors could be affected by the temps if they aren't on the suction side of the turbo from my thinking..... But others may have a proven answer
Edited by Badgaz
Nistune will get you in the road. Z32 AFM is good for more than 300kw - how much more seems to vary . There are apparently more than one type of Q45 afm and some are good for better than 400kw..
I would keep the Nistune and Z32 and save up for a better ecu such as Link/Vipec or whatever you like later.
Just to elaborate on my previous comment.
Nistune will log all ecu parameters.
In order to log more you need something else. I use a zeitronix zt2 which does wideband O2 and a heap of other inputs and Nistune picks it all up. I only use one for boost as I don't need to or care about logging others.
Look at blah blahs' s result. I think that was nudging 400rwkw not sure on the afm he used.
My understanding is that the afms have an airflow limit which roughly translates to a power limit. But on e85 you make more power for the same airflow so that power ceiling is a bit higher
According to nistune the z32s are good for 500hp (from memory) but probably a bit more on e85
The other thing is you might want a 4inch intake on that set up
Its not that the afm actually restricts airflow to create the power limit, it's due to the sensor being unable to read any more air flow.
The sensor outputs 5V (max) and then the ecu and tuner have to guess. Which isn't ideal.
Definitely will not be getting a Link G4+ as i know i don't need something that powerful for my applicaiton, and the budget is already being very stretched to cover the Adaptronic. I understand that what Ben said is correct, the AFM can only measure so much air (which translates to so much power) before reading 5v and then any extra air that does flow through is not recorded.
Was also looking at the Q45 as someone suggested, the advantage to that is its 90mm and would fit better in my intercooler piping.
I don't care about data logging, all i really need is wideband input and i am happy, which NIStune will provide.
could you put the z32 into a larger tube? i think the z32 still has better resolution than that q45.
Sort of. The sensor is part of the body so you would have to do some hacking. It would also make thing difficult as there won't be a pre existing table for voltage vs airflow.
All afm's have the same output of 0 to 5V it's just that most max of to 5V at a lower air flow.
(Not really true as some use a pulse signal but not nissan so who cares! )
Hpx make custom airflow meters that read alot of air. Matt at nistune amongst all his other work is looking at creating the neccessary tables to use them.
Edited by Ben C34
That's what I meant I didn't mean to infer that the 80mm pipe will be the power restriction
stick with the nistune and use a vh45 afm if you need the extra resolution.
use the money you save for more tyres :yes:
Just doing some research on the topic and i saw that back in 2011 you said you were running a Z32 in your cooler piping. Was it cold side or hot side? No noticeable issues?
Turbo outlet is 2.5" so the 3" Z32 is already bigger than my cooler piping. Will have to step it up to put the Z32 in there
Also i won't be running a BOV if i don't have to.
Edited by iruvyouskyrine
Use a R35 AFM in a larger tube..
food for thought:
http://www.pmas-maf.com/store.php#!/~/product/category=8217001&id=32363037
Nistune doesn't have wideband input, only uses the factory narrowband.
The wideband is read by the software on your laptop only through a serial output from your wideband controller or gauge (all in one units)
food for thought:
That looks interesting. Could just stick that in my 2.5" intercooler piping and forget about it rather than having to try and fit the Z32 in there. I am still not sure if i should put it in the hot or cold side of the piping though...
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
