Its running a pfc, and while it was tuned atleast three years back, it hasnt had any probs.
Im thinking ill have a play with some wiring and see if it changes idle at all... Just wish i had more time to play cars...
Yep, front of the head, sticks out about 50-70mm and has a red/black plug on it
Pull that out and see if it either fixes the problem, or makes the problem constant. If so then not so bad news, might just need a new VCT Solenoid/Switch (this thing your unplugging) or a minor re-tune just to touch up the VCT issue. Perhaps a mix of both
Start the car. Take a screw driver and put the metal tip against the injector. Put your ear to the end of the handle. You can hear the injector clicking, it's working. Go thru all 6 and learn what to listen for. This is the first step of diagnosing a bad injector. Step two is ohm resistance. With the motor off, unplug the wire clip to suspected faulty injector. Use a multi-meter to read ohms. You're looking for anything that is not in the 14 ohm area plus or minus 1.5 ohms. You'll use both prongs of the multi-reader and touch each of the injector electrical prongs. Polarity won't matter. This will tell you if the electrical coil is bad inside. Unfortunately they cannot be rebuilt and the whole injector will needed to be replaced. If replacing a single injector, it's wise to remove the rest and having them professionally cleaned and flow matched to the new one.
If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. post-116132-14045372547201_thumb.jpg
These are Nismo 550cc side feed at high impedance.
These are aftermarket top feed that can be high or low impedance depending on your personal engine build goals. Easy to spot. The stock side feeds are purple in color if I remember right.
Here is a website that can help you more with specs:
http://webbersrbguide.com/index.php?option=com_content&view=article&id=64:skline-rb-standard-injectors&catid=45:wiring-electrical-a-ecu&Itemid=23
  • Like 1
Yep ive done the screw driver listen and also the swap, injectors are fine it seems so its electrical or vct, ill check it out further and find an answer...
Thanks for all your input it is much appreciated, just wish i could dedicate more time to it...
If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. attachicon.gifImageUploadedBySAU Community1404537253.775014.jpg
Thanks for the link mate, very helpful :)
Ok im still trying to sus this out, ive tried unplugging injectors one at a time and all make a slight difference to how it runs, ive changed spark plugs, removed coil plugs ones at a time each makes a difference to how it runs...
I havnt had a mechanic do anything on my car other than tune or fab work for years, normally do everything myself, but i may have to bite the bullet cause this has stumped me... Silly cause i feel i caused it.
Could an electrical issue cause by moving old heat and weather affected wiring harness...
It could be, but the filter isnt that old, and it was running fine before painting some parts...
But now that youve said that perhaps i should change it just to be sure...
Put a mesh 40 micron on there, all the blocked ones I have seen lately have been Ryco style paper ones. Never had an issue with stainless mesh filters.
It could be worth checking the contacts on your ECU plug. I had a similar issue with one injector not firing and it turned out to have a bad connection for that injector on the ECU plug.
I closed the female connection a little, plugged it back in and the problem hasn't resurfaced.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
